Everything posted by DerFahrer
Is it just me...
Having not even driven my 79 yet, I can't attest to its power But... the FSM says the torque is only like 80 ft-lbs or something, BUT it peaks at 2500rpm!! That is a thing of beauty, and that can only come from a 2-valve, single-cam, pushrod design. Doesn't do jack for power, but it allows for a lot of torque. My XT, as well as most all EA engines, are the same way.
2005 Legacy 2.5GT FRIED!!!!
DerFahrer replied to Gravityman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's more than just a one-time occurrence, I'm afraid...
WRX clutch kit work on a 93 Legacy?
DerFahrer replied to 88HatchMonster's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou need a Legacy Turbo transmission to use a WRX clutch. For the most part, all nonturbos use a certain type of clutch, and all turbos use a certain type of clutch.
76 DL Sedan : Nice
I would pay $1800 for that... If I had $1800, and if I had a way to get the car down here, and if I had a place for it once it got here :-\
Zee Toy Brat Turbo and friends!
No fair... I want old-school Subaru models... Yep, that is a GenI Brat...
Subaru Rex - Parts Wanted
Actually, that is essentially our Justy... Your headlights are different, but the platform looks the same. What are the 4th and 5th digits of your VIN number? Still though, our Justy only had a 1.2 inline-three. Yours is a 600cc engine, which we never got at all.
As Kostamojen said, no US dealer will have parts specifically for a Rex, unless it was the newer Rex that IS the same as the Justy. Yours looks similar to this right?
The worth of my Loyale?
As long as it has no rust on it, I would say it's worth close to what you're asking...
rag joint :73:
Is it a circular piece of rubber with 4 holes in it? Right before the column shaft enters the rack?
EA-82 RS Turbo?
Consider yourself lucky to have even seen one. Loyale Turbos are rare enough, a 3-door even more so.
rag joint :73:
I've never heard the term rag joint before... Is it the joint in the steering column, the one that allows the column to bend down right before it goes into the rack? If so, you're in luck, because that joint (usually called a universal joint, like the ones in a driveshaft) is still available from the dealer, part number 731037160, list price is $145.20. 3 in the country at the time of this posting.
Pics of my new Brat
Looks like the only place with any significant rust is the tailgate... Still looks cool, and I feel uncomfortable admitting it, but I like that color
Back home at last
Nothing wrong with being excited and wanting to share it with others. Looks very nice!
Late Sept. early Oct. OBX East Coast gathering??
The hour is fast approaching, any interest in this still?
Is 2nd catalytic required by law?
DerFahrer replied to Vanguard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNoah is right. If you want to get technical, your car is illegal if ANY of the emissions equipment that originally came on the vehicle from the manufacturer is not working properly or missing. No matter which state you're in.
Cold Weather Package
We're just mad at you coz you keep scoring all these NOS parts
Autocrossing the Loyale this weekend... tips?
Like NorthWet said, don't worry about not having power. In fact, the fact that EA82's are all-torque and no-power could make them a lot more formidable on an autoX course than most might think. Where WRX's are stumbling off-boost, you're pulling forward with authority. The problem is the pronounced understeer and the nonexistant suspension options. I know you don't have time this time around, but if you plan on competing with the car in the future, install a rear swaybar from a car with air ride, like my XT. The air ride cars have the thickest swaybars, and if you put a thick rear swaybar where there used to be none, you will have a much sportier-driving car right off the bat
Subaru Engine Designations
DerFahrer replied to Steve B's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhoa... information overload!! Did some browsing through the model information for much of the Subaru line... There are also EJ222's and EJ223's, as well as EJ252's, and EJ259's. Once I recover from the meltdown , I'll try to see what car has what. Oh, and the 1000 never made it over to the US. It was in the JDM FF1. So that's probably why you can't get any info on it.
DerFahrer replied to Steve B's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have just confirmed that all 3.0 sixes are EZ30D. I'm finding more out right now...
"For every job that must be done.... " :73:
I'd likely be up for that...
Exhaust Hangars
Good find Kosta... In that case, that also means that the STi exhaust hangers will work, part number ST440314SS000. They're stiffer than the stock ones, which means more NVH from your exhaust, but they should also last longer
DerFahrer replied to Steve B's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI see a few errors, and one I'm not sure about. First off, are you sure the 360 motor is an EA designation? The 360 engine has virtually NOTHING in common with any boxer engine. And where's the 1000 engine? The Impreza 1.8 is an EJ18, not an EA18. If you want to get technical, it's an EJ18E. The SVX is technically an EG33D. The WRX 2.0 in America is the EJ205. The EJ207 is the JDM STi engine. There is no EZ30R. All 3.0 6cyls are EZ30D. There's a few HP and compression anomalies too, but I'll try to look those up later. That's all I can confirm at the moment. I might find more stuff out later.
A-pillar Guage pods in 79 brat!
Pretty snazzy! Where did you get the trim piece from, to mount them in?
73 : got it home and got it running great
Wow. Just wow. I'm jealous. Your 73 and 78 are in better condition than my 91 Legacy
??? about the ej18
DerFahrer replied to crazy D's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEJ18 has 110hp. It's just as reliable as the EJ22, maybe more so actually. Yes, nipper, the EJ22 has a larger bore If you do get an EJ18 for a swap, get one from a 93-94 Impreza, so then you don't have to deal with EGR stuff.
