Hey guys, I read a bunch of old posts but registered an account here as I am still at a loss, and hoping someone smarter than me might know what's up.
Old family subaru has been sitting for a bit, I don't know the whole story but I think it was running til parked a few years ago. I trailered it back to my house to try and get it running.
I've got it to where it will crank very hard, and run as long as you spray starter fluid into the throttle body, or it even self sustained off fuel leaking directly into the cylinders when I had the injectors pulled.
Injectors were pulled, tested, and pop hard outside the vehicle
Fuel system was cleaned and new filter and good fuel is making it to injectors, but no fuel is getting through them at any point. With key on all 4 injector leads are reading 12v. I have yet to get any injector to spray from a key on or keyed start, only when bench tested outside the vehicle.
Resistance of the injector leads back to the battery ground were 4/4 ~1ohm on the ground side.
The ECU is reading 0 codes....which seems....suspect
Now Reading P0201-P0204 (injector circuit open)
anyways I'd appreciate any help
Thanks,
Chris
