kruteck
2
kruteck last won the day on March 26
kruteck had the most liked content!
Location
Portland, Oregon
Vehicles
2001 Subaru Forester
Recent Profile Visitors
kruteck's Achievements
Newbie (1/11)
4
Got the coolant temperature sensor and the purge control valve replaced. Filled the overflow coolant reservoir between the low and high marks. Filled the radiator with coolant and filled the funnel about half way. Started her up. Ran fine. Burped several times. Let it run for about 15-20 minutes. Temp gauge never got above normal. Radiator fans never came on. Coolant eventually started boiling. Shut her off. Will let her cool down, then try again this evening. If I get the same result, I'll leave the radiator cap off and check the level in the morning per ocei77's suggestion. Can't figure this one out.
Finally got some time to get back to this. Cabin heater is working, so not the pump. I also tested the fuses and relays for the radiator fans. They tested fine. I did a bit of research and found out about the green connectors under the steering column used for diagnostics. When I plugged that in and turned the key I heard lots of noises and clicking. The radiator fans were working. I dug into the engine to find the temp switch, per Imdew's suggestion on 3-14-2025, which I believe is also called a coolant temperature sensor. It's kinda buried underneath alot of wiring. I unplugged quite a few electrical connections to give myself enough slack to get to the coolant temperature sensor. I was able to access it and unplug its electrical connection. There was a small hose I wanted to remove to get better access for the wrench, and when I put my hands on it I realized it was broken. See attached photos (#1 and #2). I put a circle around the sensor and a rectangle around the hose. Unfortunately, the plastic nipple is broken. I think I'll need to replace the part the nipple is connected to. Hopefully not, but my gut says that's the way it's gonna go down. Anyone know what this part is? The hose that connects to it goes under the intake manifold and then travels off toward the driver's side of the vehicle. For reference, there is another black nipple to the left of the broken one (see photos #1 and #2). It's intact. The hose that connects to it travels up past the coil. The attached photo (#3) shows a wide view of the hose/nipple that's broken (bordered with a rectangle) and the connection past the coil with a triangle.
I replaced a timing belt, water pump, and thermostat recently. I drove it for the first time since and I heard gurgling. It dawned on me that I forgot to burp the coolant system. I drove it a few more times with no overheating issues and finally got around to burping it. I rigged up a funnel in the radiator, started the car, and started adding coolant. It took a few cups of coolant, then looked as though it was full, so put a bit more coolant in the funnel and let the car idle for about 5 minutes. It burped once or twice, but that's it. I let it continue to idle. I was expecting the fan to come on at some point, but it never did. This perplexed me a bit because the fan worked prior to and after installing all the new parts. The upper and lower radiator hoses were warm/hot to the touch. No more air bubbles showed up even after 10 more minutes of idling. At this point the coolant started to boil. I put the radiator cap on and shut the engine off. I wouldn't think it's a thermostat issue since both hoses were hot. I suppose it could be the water pump maybe, but it's a brand new Aisin pump. Still not sure why the fans didn't kick in. Any ideas would be appreciated.
I had all the cam and crankshaft marks lined up during the install of a timing belt when the driver's side cam moved several teeth (2 inches) counter-clockwise. The belt was tighter than I was expecting and I must have pushed or pulled a bit too much. Anyway, it moved quick, like it was spring loaded. I'm not sure if the next thing I did was smart or not. I put a wrench on the cam bolt and attempted to move it back so the marks lined up. I was almost at the mark when the cam then jumped 2 inches the other way (clockwise). I put a wrench back on it and was able to get the marks to line up again. Did I just screw up by moving the cam independently of the crankshaft and other cam? Did moving it in both clockwise and counter-clockwise cause some damage? Not sure if I'm in a jam or not.
