xfinrodx
About xfinrodx
- Birthday 03/15/1987
Gender
Not Telling
Location
Portland, OR
Interests
Cars, computers and family
Occupation
Good question.
Vehicles
1988 xt6 RIP, 07 Impreza 2.5i
xfinrodx's Achievements
Member (2/11)
10
final drive ratios on xt6's
xfinrodx replied to xfinrodx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
All autos are the same then? I may just yank out the little tranny speedo assembly tomorrow then, and put it in my driver if it passes visual inspection... thanks for the info! -
Hey, I believe I have a little gear that powers my speedometer cable. I have a 1988 xt6 4eat. I also have a parts car; a 1988-9 xt6 2wd. What are my final drive ratios? I'd really like to know if I can swap the little innards so my speedometer works right again. Anyone know xt6 final drives? Thanks--
Hey folks, I know this would probably have a better home at xt6.net, but no one there seems to know: Is there any way to lock a 1988 xt6's awd auto tranny into a 50/50 torque split? It does a cruddy (for snow) 90/10 split standard, and I'd like to maybe short a little signal wire to get that elusive computer controlled 50/50. Any help would be so much appreciated that if I appreciated it any more it'd be indecent. Thanks!
Sicko..... No sacrelige here today. Can't fool me either. I know full well that won't bolt in!!! It'd take some crazy insane modification.... Let me know how it goes when you try! I deliver pizza for Domino's in this car. It shouldn't be out of commision for too long... (An engine/tranny swap is an acceptable amount of time... not a sub/chev swap!)
Well, I posted the other day asking about my head gasket issues. Seems as if I will need to get this fixed pretty much NOW, as it's getting very hot outside and my car is trying to melt down. Anyways. On to the topic: 1: I would really just like to be done with this 230k mile motor and have a different one. I've found one with 71k on it for 400 bucks. Is this a rip off? 2: I'd like to do a manual tranny conversion at the same time, if parts permit. I know Suberdave had a kit available several months ago, but I think he sold it. Does anyone have a 4x4 manual tranny kit (minus the tranny)? 3: Are there other (more powerful and preferably more readily available) motor/tranny's out there that would bolt in that I should look into instead of the 2.7 '88 h6? Thanks for taking the time to read! Kenny
You folks are cool. Thank you crazy lots for spending the time to bail me out! Kenny
So my 88 xt6 has this funny little problem... It won't stay full of antifreeze. "Fix the hole, dummy!" Well I'd do that, but it is exploding out of the burp tank. "Don't overfill it, dummy!" Yeah, I'm not at all. When the car gets hot it just starts bubbling in the burp tank like crazy. Doesn't seem to be "boiling", but rather just expelling lots of air. Maybe it is boiling, but it doesn't seem like it. Would this maybe be a blown head gasket letting air into the coolant lines? Another thing it does is this: Randomly, when I first start it, when I take off to drive at a normal pace, it craps out, completely powerless and sometimes makes a couple few hollow "pow" noises. Real descriptive, yeah I know.. I fix it by flooring it and taking it to 4-5k rpms. It clears out and doesn't do it again at east until I start it again, but usually not for a couple days. Head gasket again, letting crap into the combustion chamber maybe? The third issue I'd like to ask about if I may is this. My car pings a LOT when drawing heavy compression (ie, when going up hills). Where should my timing be at for a tired 230k mile motor? The thing pulls like crazy, but it is old no matter how you look at it. I tweaked it forward a bit to try and slow the pinging down a bit but it didn't do much if anything. Would that maybe be my belts having jumped teeth? (Oh shoot.. is the 2.7 h6 engine an interference setup?) Boy, that's a pathetic lot of questions:rolleyes:. Sorry bout that. Anyone have any ideas or confirmation of my guesses? Kenny
Thanks. I'll go do that.
Hey, I'm in the market for a good k&n air filter. I popped my current filter off and drove around the block and... my car was like a screaming fast hot rod. Put the filter back on and it's just fast. What to do then? Can't drive around without an air filter... K&N time. There is a stock fitting filter available for my car, but will that perform as well as I'd like? Is there a cold air intake available that I've not been able to find? I drive an xt6 with the 2.7 h6 aaand I want to make it go as fast as possible. This seems like a solid, cheap boost. Any suggestions? Kenny
Really Stoopid Things We Have Done
xfinrodx replied to subbum's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My dad's all cool in his big ford 4 wheeling f-150, says I should go snowdrift breaking in my 1986 4x4 wagon on a particular road. So what do I do? I go to this road. Man are those big drifts.... I rev that 4 banging monster on up to 45 mph and boy I HIT that drift. Up over top I went on it, slowed down, got stuck and couldn't get out of it. I got towed free of it shortly later, and after frostbiting my hands trying to dig myself free (note to self- bring shovel when snow hunting). So I went for a short drive to make sure nothing was broken because I just buried my car in snow up to the doors... and the car overheated. ...say again? The car overheated in the snow and ice and -10 degree weather? Yes. Yes it did. And badly too. I stop, pop the hood, and when the steam clears I see a pillar of snow and ice between my radiator/fan and engine! Not only that, but my entire engine compartment is filled, PACKED with snow halfway up to the carb -
Hey folks, I may be able to get my hands on a fwd xt4 manual. Can I steal the console, instrument panel, pedal assembly, and speedo cable from it and slap it together with the xt6 tranny and all that?
It'll all be done at once. I'm going to have the parts sitting 10 feet away from the car when I get the car up on the lift. Well, all the parts that can possibly be anticipated. I'm not going to float it with fwd. Good info for when I need the car and things are going poorly though! The subaru dealer will be able to check the id codes, huh? That's grand. Thanks people. Any more talk about anything related to this would still be helpful if there is anything more to talk about!
Alright folks. I have a line on a 5 speed trans for fifty bucks. I don't have the rear end to match, so yeah. I really gotta know how to tell what the ratio is on the trans! Anyways, I'll be patient for someone who knows all. See if I can find huck... Thanks Kenny
Ok, so they virtually all bolt up, but how many will work right with the 4wd? Lots and lots of vintage 90's subarus are 4wd but... Lots of them are lever select or something to that effect. It would be cool if something else (maybe a legacy) would bolt on, 4wd would work, the driveline would be happy, and the rear end would be correct. Yeah. Donor cars are the way to go. Still gotta know though, if there's a way to tell the 3.9 from the 3.7 trannys.... It might need to be a little bit of a piece job, depending on parts availability. Kenny
