28
Everything posted by Turbone
Need help diagnosing this new noise
Turbone replied to goatman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check to make sure there isnt any cables or whatever rubbing on one of the axles. Sometimes theres stuff on the road that can be picked up and wrapped around an axle also. Rob -
Were the wires the type that are pre-made, or did you have to make the ends up? I would check all the SP connections, they have a habit of not going on all the way when they are new. Same with the disty cap. Oh, and make sure the cap is ok too. Rob
JC Whitney has digi gauges. Never bought any, just seen them in the catalog. Rob
New Forum? Sticky maybe? Or slippy maybe?
Turbone replied to WJM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well, now everyone will want thier own forums. Offroad Forum, Street Forum, Turbo Forum (EA81T/EA82T seperate Forums?), NA Forum, Hack Forum, Beginners Forum, Advanced Forum, Add Infinutem. See what I mean? I think we can keep it all in the Old Gen forum so we dont have to keep jumping around. In other words, Keep It Simple Stupid (KISS) Rob -
Hood release cables- Can they be repaired?
Turbone replied to moosens's topic in Old Gen.: 80's GL/DL/XT/Loyales...
NV, its the slug on the end that broke. Moosens, if you need one, I got it. Rob -
From Skips post, he didnt say if the car died. I'm going for a shredded Alt belt that took the wire off the oil sender. Rob
THats a bugger to get to. Its almost located directly above the fuse panel, and attached to a bracket off the upper firewall. And you know what that means:D And yes, its a round silver unit. Rob
Part number needed for door seals
Turbone replied to torxxx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I dont think either one of them would carry it.I think JC Whitney is your best shot. Rob -
Busted hood release-How to break into hood?
If you dont want to mess up the finish on the hood, use a flat piece of metal stock about 1/8th thick. The latch is on the right side (you prob knew that) and push towards the right (you prob knew that too). Rob -
1977 Subaru Brat: Trickest Trucklet Around
Turbone replied to DahlEd's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Nice article, but unfortunatly the pic they show is diffenately not a Brat:mad: Rob -
Congtrats on finding the problem. Your troubleshooting skills have increased greatly, nice to have FSM's. Is it running yet? Rob
8 yr old daughter building EA-82
Turbone replied to brat86's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yea, I kinda miss those days:D Btw, my first car was a 68 Firebird, black with white interior and slotted mags. The car was only 8yrs old when I got it. Alot of you werent even around yet:eek: I have my 12yr boy help me sometimes, mostly manning the jack. But he asks lots of questions, and its fun. Just wish his attention span was longer. Rob -
Same here as a kid. I was my Dads gopher and mule - go get the saw and that pile of 2x6:-p He knew nothing about mechanics, but he could sure build with wood. Learned alot on my own working on bikes, helping friends with thier cars, till I got my own car. Rob -
Its under the passenger seat. Theres 2 of them, one for the ignition and the other is FP relay. Disconnect one to find out which is which. No luck with the connection at the pump? Rob
New stuff for our old stuff, nuts only!
Good to hear about the fuel filter. Normally these cost around $20 cause they are high pressure. How long have you used yours WJM? You will let us know if it blows, right? Rob -
bought a wagon, need a part now.. pics!!
Turbone replied to Meeky Moose's topic in Old Gen.: 80's GL/DL/XT/Loyales...
All of mine have pulled right out. And yes, they have diff oil in them, not ATF. Meeky, sounds like a seal went out between the diff and tranny. Rob -
Where can i park ANOTHER subaru???
Turbone replied to TheSubaruJunkie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ok Brian, here you go. You will have to give up the 84 Turbo coupe:rolleyes: Dont leave me hangin Bud. Rob -
A diff that cores a Gov that bad will core another one. Cant tell you how long it will last, after my 2nd one they only lasted about 60mi. And its really hard to tell how bad the shaft is inside unless you pull the diff apart. Altho splitting the diff off the tranny isnt that hard, its just a pain pulling the tranny period (this I do know). Rob -
Question about gl-10 auto trans
Turbone replied to hush777's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Doh! Calebs right. All AT's are 23 spline. Darn, I even messed up on the ratio:rolleyes: I better stick to EA81's. Rob -
The stubs are 25 spline. You might be better off replacing the whole tranny. The 5spd conversion is doable but very labor intensive No one I know has a manual. The ratio is 3.9 Rob -
Knock knock knockin on Billy C's door?
Billy, would one of theose "leftover manuals" be a 84 electrical manual? The one I paid you for around 4/03? Sure like to get it before it goes to someone else. If you need my mail addy again, just ask. Rob -
new engine dead???? aargh
Turbone replied to baccaruda's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well, it could be a number of things. Most are related to faulty parts/assembly. One possibility is a bad head gasket. I think I would check into that and rule it out before damning the rest of it. If you take the heads off, check for broken springs, etc. Rob
