28
Everything posted by Turbone
Why? The Porche engine has more HP than any Subaru. Rob
Knock knock knockin on Billy C's door?
Turbone replied to moosens's topic in Old Gen.: 80's GL/DL/XT/Loyales...
IF we get ahold of him and IF we make a group purchase, does that mean I have to pay twice for the item I ordered? Sorry, I dont think I want anything to do with it. Good luck finding him. Rob -
Hey Caleb, those are 2 different plenums. How much polishing did you need to do? Did it have ridges like the other 4wd one? Rob
How to prevent a kinked (flattened) radiator hose?
Turbone replied to sub87dl's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You may have to get a molded hose. Rob -
mechanical questions--advice needed
Turbone replied to Buddythedog's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Do you have a manual? Its alot easier than running back and forth to the computer. We do like to help, but if you are going to do any maintenace on your car, it really helps to have a manual. Rob -
Ok, I think I can handle the hold. Nothing wrong with my hands. Rob
Ok, now what you need to do is tape the camera to the bumper and make a run up and down the street:D That way we can hear it going thru the gears:grin: Rob
What the ???? is this thing
Turbone replied to HardcoreSoob's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Without a pic to go by, it "sounds" like the noise suppressor unit. Rob -
Well, its definatly a bearing. But theres no way for any of us to know where or what bearing, cause we cant hear it from here:D Rob
I have to apologize. Andy is correct. My waterpump did make odd noises, but it wasnt the goose noise. When Andy posted about the fan, it jogged my feeble memory. My rad fan was the goose noise, the bearings went out on it prior to the WP going out. My bad, and I deleted my previous posts:rolleyes: Time to order more Focus Factor. Rob
No Tim, thats dinner:D
These 3dr Coupes were made from 85 to 89 (pretty sure). The engine classification is EA82. When you order parts make sure they know its a 3dr coupe, not a 3dr hatchback. Rob
Who belongs to this subaru?
Turbone replied to Snowman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yup, the one and only. Rob -
It looks like it came from of Todds rigs. Lives up in Mt Vernon, Wa. A very interesting guy. He has some of the most "unusual" Soobs around. http://usmb.ultimatesubaru.org/forum/member.php?s=&action=getinfo&userid=776 Rob -
t-belt cover what if..... continues
Turbone replied to subiemech85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I can probably make it out of wood:brow: Rob -
How much more room do you need? It may take a spacer to drop it down to clear the trans. I would remove it for now, then after the tranny install try and get it to fit. Do you have a lift in? It looks pretty tight in there. Has anybody else done this swap? Sheese, I have more q's than Shawn. Rob
Your car has points? As far as I know they havent had them since the 70's. Rob
I think he's still atached to Lewy;) Rob
Wah:boohoo: That really sucks:( Nice score Mc;) I got my eye on it now. How much for shipping from the UK? Rob
Silly EA82T coolant problems
Turbone replied to drewcifer85710's topic in Old Gen.: 80's GL/DL/XT/Loyales...
A common problem with these are the waterpumps, or to be more exact, the waterpump to lower rad hose o-ring. On the right of the waterpump theres a large metal tube that comes out about 8in, and then into the lower rad hose. Theres an o-ring on the end of the tube that goes into the waterpump. The o-ring comes with a new waterpump. This is just an option, and probably wouldnt hurt replacing before summer gets there. Rob -
Turbo wagon runs again.
Turbone replied to SuperRallyRoo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ditto on that. You most likely have the disty off a tooth or two. Rob -
Maybe even a cooling line came loose. Rob
You said the voltage at the switch when operating is .04. Whats the voltage to the switch from the module? Maybe a bad connection in between? If not, its most likely the switch. If you need one send me a PM or email. Rob
'86 Wagon Bumper & Tail-light Removal
Turbone replied to DPDISXR4Ti's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You need to lift the little cargo flap in the rear deck, bolts are 2 on each side. The nuts for the lights are located behind plastic covers in the corners. I think they are 8mm. Rob -
Those are airplane engines. Rob
