28
Everything posted by Turbone
just testing the H20 -> alt. repair art.?
Turbone replied to Skip's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Real nice setup there Skip. I've torn apart one Alt. to find out how much of a PIA it would be to rework one. Not that hard really, if you have any soldering skills. I called a local auto elec place and the rectifier is $35 and the regulator is $25. A previous post about the same subject has some interesting prospects on the GM/Chevy alt's. Maybe a write-up on both (ie, upgrade on the American alt) would be a good addition to the USRM. Do you have any idea why our alt's get toasted so easily? My assumption is the high R's, maybe a bigger pulley would slow the alt down. Rob -
Need hints on finding a new Subie
Turbone replied to the_bard's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I dont know about the 90's, but earleir Soobs have the VIN stamped on the firewall also. Rob -
Is there a chance the lever could have broken off? There should be the end of a cable down there if so. The switch could be for a set of driving/fog lights. Rob
Hey Del: Pics of your Guard
Turbone replied to Adam N.D.J.'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hey Del, I'm selling my 84 Turbo Coupe. I'm in the process of repairing some minor rust and doing a tranny swap (keeping the 3AT 4XPB). If your interested let me know. Rob -
X-member, and I dont know what the suspension is like on a pre 80's Soob, but you might consider changing over. Rob
I have 2 questions. How did he do the rear handbrake? And how did he widen the wheel track? That is one pretty Brat. Rob
Had email correspondance with him 3/4 months ago and he said he would get my item (84 elec manual) out to me. It still hasnt arrived. I think Billy really screwed up on this. After saying he had a warehouse of parts he was getting and promising everyone lots of parts, he's only come through for a few people. I'm only out $20, but now any of the stuff he has or was going to get to others will never see the board. He's lost all credibility in my book and will not ever give him the chance to take my money again, or any one elses hopefully. I know he just got married, etc etc, but if your paid for something you promised, either deliver or give the $ back:madder: Rob
If the oil seal is leaking, you will find excessive carbon deposits on the tubine, like on a sparkplug. If the exhaust smoke is blue and you suspect the compressor side oil seal is leaking, check for excessive oil in the plenum. If its obvious that the turbocharger is blowing oil into the pipe, first check the PCV system and other possible engine causes before condemning the turbo.. Rob
Might help if you dropped the steering colum down, give you a little more room to remove it(little voice of exp:brow: ) Rob
I've heard of a couple people taking the exhaust off and putting a coat hanger down the inlet, then picking out the guts. Personally, this would take way to long. I used a die grinder and cut a good sized flap in it. Its still a PIA to get the stuff out, and welding it back together is touchy. The metal is 2 layers thick and different gauges to boot. Rob
I've got some 'radical roo' pics to post ...
Turbone replied to mtsmiths's topic in Old Gen.: 80's GL/DL/XT/Loyales...
And post a link so's we can all see it:D Rob -
is the same. Locking the doors turns off the light. My parking brake light is the one that flickers. Rob
pushbutton 4wd won't engage
Turbone replied to thealleyboy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Andrew, I was thinking AT, not MT. Thats a real lamer too, I have the same tranny in my 86 GL-10 Turbo wagon:banghead: Rob -
The coupe motors will work, not sure about the wagons tho. Shorter doors could mean shorter arms, but thats not for sure. If Qman doesnt have any, I might have a couple lying around. Rob
Vickaroo, would you like to talk to my wife? Actually, shes pretty good about stuff I bring home. She just doesnt like to see parts cars hang around to long. Rob
Check your fuses, its electrically operated. If those are ok, check the connector on top of the tranny (PIA). If thats ok, then thers a problem with the selenoid. On the 80's models its located on the right side toward the rear of the unit and about the size of a ......axle nut(closest I can come). All it is, is a pin that goes in/out to engage 4wd. Rob -
ground wire question on my new radiator!
Turbone replied to tompalushock's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes, it helps ground the fan(s) to the chassis and engine. There should be something like a flange or lip on the new rad to screw it to. Rob -
Thanks Caleb. But what Soob doesnt leak oil? Rob
Is it below the idiot lights? In the manual(86) it shows the rear wiper and washer switch in that area. Rob
That I have a SPFI in a 88 (I think). This was a car I got from Calebz, and he said it was running. Email me for more info. Rob
Nice seeing you guys, glad it was in the Mt's:brow: Its a good thing you all dont live together, it wouldnt be safe around here:lol: Andy, thanks for the pipe(exahust folks), I'll make good use of it. When the $$ is available I'll get ahold of you. Rob
Normally the cool down period for the turbo is so that the oil circulating will cool off and not produce whats called "coke" in the bearings. Reoff, I think you might have had other issues that led to you cracking both heads. You might have Gen 1 heads that are prone to cracking. I would get a bottle of MMO, maybe 2 for 2 oil changes. It might help the valve ticking. The bubbling could be air in the heater lines, its common. Rob
