jeffast
Everything posted by jeffast
  1. sorry i couldn't ressist the urg to use that smilie i'll wait
  2. wtf???i gotta agree with gd you posts are like chinese, my heat is cold, the reason the heater core is plugged, the fix simple first flush it out, second if that doesn't work get a new one wtf does painting hoses have to do with any thing the differance is going to like 1/2 a degree, jeff
  3. i think you need to upload an audio file along with pics:headbang:
  4. the timing is way advanced i checked all my plugs this afternoon i guess it's time to replace the wires in the harness:mad: sad panda
  5. it's also dogging a little i'm stumped
  6. i'm stumped my xt-6 runs fine, but it is verfy hard to get it started you have to pump the gas and crank it for atleast 15-20 seconds before it will start
  7. operating temp for an 02 sensor is like 6-900 degrees, most cars exhaust is not hot enough at idle to get accurate readings, thats why most newer cars use heated o2 sensors,
  8. definatly looks cool i'm sorry i'm really tired i'll edit the first one tommorow to make more sense night all
  9. it's because you don't have a wideband o2 sensor, standard o2 sensors just read rich or lean thus the bouncing a wideband will give you an accurate readding of how lean or how rich, or you can just us it to keep an eye to make sure evrey thing is normal
  10. i'm scared now, i mena i worked on it and it actually runs:headbang: congrats mike
  11. that sounds like the mess i found on my six's drain plug after i blew second gear, i wish i still had the pics of that
  12. i think the suibaru 1600 was built into a rally car but i could be crazy
  13. on the front diff yes,tranny plug no, on my friends aerostar we found a bearing race stuck to it, he sold that van really fast for some reason, i found a 1inch tooth off the pinion on the rear diff on my truck once, that was fun
  14. that's a good theory it suddenly puts the cheese wedge into perspective, right mike?
  15. i have no clue but it would be a better idea to put this in the new gen forum this is the 80's forum
  16. he has one stick for 4wd and anouther stick for hi and low, so he can use low 2wd for getting started on hills and such
  17. i've heard of this dr krazy has a twin stick for his lifted sedan for 2wd low, he blows front axels left and right, since he did it
