				Posts1992
Everything posted by jeffast
	pics lets see her restored to glory:headbang: glad they did a bad job
	that was totally awsome and kinda scary at the same time
	my friend has a bronco that will pivot on one wheel
	  Has anyone ever had an EA82 transmission rebuilt?jeffast replied to Syonyk's topic in Old Gen.: 80's GL/DL/XT/Loyales... i had an xt-6 tranny with a bad bearing re done by ccr
	i thought i felt my rx sense tingleing
	  bad PCV valve cause excess moisture in crank case?jeffast replied to Ross's topic in Old Gen.: 80's GL/DL/XT/Loyales...
	  bad PCV valve cause excess moisture in crank case?jeffast replied to Ross's topic in Old Gen.: 80's GL/DL/XT/Loyales... that was thermostats
	  Hello from a new Rocky Mountain memberjeffast replied to Matt Monson's topic in Meet n' Greet. Your USMB Welcome Center welcome to the board
	good luck with the repairs, accidents happen
	nice they look good together:headbang: you should paint your wagon yellow phil
	thanks that is actually exactly what i was looking for
	i work at an auto parts store it's high we warrenty our new pumps for life and our reman's for a year had one new one come back in the warrenty period after like 6years had like three reman's plus the remans look like ************ put them side by side and there are usually two welds on eather side of the pump holding the uh thing behind the impeller in place
	  salvage yard in denver?jeffast replied to rusty89wagon's topic in Old Gen.: 80's GL/DL/XT/Loyales... pullnsave.com, also colorado autoparts, sidewinder look those up in the phone book they are my three favorites
	kinda empty on the fundage right now gotta go the cheap route
	what haven't you replaced in that general area that carries coolant? i'd replace all the hoses before i messed with the pump again
	i ment as a short term solution while you kept an eye out for one that matches
	the seat out of any sedan/wagon should fit without modification
	ok my right front wheel bearing is shot, loud grinding noise while the car is moving gets worse with speed, getting worse not the brakes, i have orderd a new bearing and i was wondering how long this should take me my first time. also could someone walk me through the procedure i'd appreciate it, also i have no idea what tools i need, where can i get a brass punch?
	  can't remember where i heard this...jeffast replied to Subaru_dude's topic in Old Gen.: 80's GL/DL/XT/Loyales... oh thanks i skipped right over that one
	  can't remember where i heard this...jeffast replied to Subaru_dude's topic in Old Gen.: 80's GL/DL/XT/Loyales... i'm confused aside from an exhaust brake on deisels, how can you increase the engine braking power, nm forget it
	ow my condolances, good luck getting it back into proper working order
	  can't remember where i heard this...jeffast replied to Subaru_dude's topic in Old Gen.: 80's GL/DL/XT/Loyales... engine braking is leaving the car in gear while goinbg down a hill letting it keep your speed down, the answer to why, you must not have mountians where you live going down a pass brake fade sucks your brakes heat up and you don't have time to let them cool, and it can cause you to lose control if you ignore it long enough
	i'll post some tommorow do you want the turbo side or the manifold side
