jeffast
Everything posted by jeffast
  1. yes you do have to remove the timing belt covers to change the water pump http://www.ultimatesubaru.org/forum/showthread.php?t=24933&highlight=different+waterpumps this should help you figure out which pump you have
  2. um, i think they were availble in just two different lenghts but i forgot how to tell which was which edit:http://www.ultimatesubaru.org/forum/showthread.php?t=24933&highlight=different+waterpumps this should tell you what you need
  3. huh, well i'm stumped, i'd fill it back up, start it and see if you can see where the coolant is comming out of. i'm out of ideas
  4. the weep hole is the 1/4 inch hole in the bottom of the pump, if it's that new though i would start checking hoses, if you don't have any bad hoses i would start to blame the gasket did you use any sealant rtv etc when you put the pump on?
  5. that's unusual, is the weep hole on the bottom of the pump blocked if so that would explain it
  6. it is possable, does your car eat coolant at any rate?
  7. some how i don't doubt that but i was wondering how long since the last time it ran?
  8. the click at the throttle body is just the injector normal noise
  9. honestly i'm probably gonna do a twin turbo setup i don't think your going to get enough volume out of a tdo3 for the er27
  10. if you read it says that he had a turbo ea82 and now has a ej22t motor in it, along with how many hrs he logged on both
  11. i don't know but i'll be the guy to pull your wagon up a hill since there won't be any jeep owners at this one
  12. i'm really tired and bored so i edited this for my amuseiment no offense russ you know i have a chevy
  13. meh i like chains but the belts break before they get enough freeplay to cut through the block, which i have heard of happening with older toyotas
  14. holy ************ at what boost level and what other mods are you planning?
  15. you should be fine with that all fuel injection is is an electric carb if it will run carburated it will run fuel injected
  16. :eek: :eek: :eek: ?????????????????????????????????????????????????????????????????????????????????
  17. me and kingbobdole are both working on turbo setups for the xt-6 but it appears that were both going nowhere at present
