Everything posted by jeffast
subaru brat cameo comic
+1
Who wants to drop $30k on this baby!
that has to be a joke
co x-mas tree run
cool glad evrey one is still interisted, any one want to set a teniative date/suggest a trail also +1 on the not needing a tree this just sounds like fun
Ram Engines Did it again!
that is sick, now i want an old wagon:-\
my gas pedal sticks
um ya the thread title says it all my gas pedal gets very stiff when it's cold it's been doing it for to long for the cable to be frayed, the reason is it only happens when it's cold outside it never does it in the summer but it's not summer anymore. i think it's just that some idiot(me) put the wrong lube on it i'm looking for suggestions to clean it out and relube the cable so it won't stick thanks -jeff
Stand down! My Subie's been spirited off a hillside near Tucson!
it could have been made into a poster quoting somthing like"wtf is a wagon doing here?" your going to say you wouldn't want somthing like that for your wall?
help need to borrow a tool
that was my thought shawn, i'm gonna try to meet with keith later this week and git-er-done then thanks for the help all
a standard torx won't work it has to be deep i thought it was a torx to, but it's not. it is a speciality tool it needs to be deep edit: if i had any money at all i'd buy one, that's why i'm asking if any one has one i can borrow
that was awsome you didn't think to get any pics did you by chance?
co x-mas tree run
i'm trying to get out of the habit of waiting untill the end before taking action
Which yellowtops work?
if your gonna be running the sound system with the car off you want a yellow top as the red top won't last as long before you will be unable to start your car
i'm swaping gear ratios on an lsd form 3.7 to 3.9 i need to borrow the tool from someone in colorado to get the diff splines out thanks in advance jeff
generally they have a 4 digit code the first two for example 58-84 58 is the battery size, and 84 is the warrenty period in months,
long term engine storage tips?
ok that's a little unorthadox, but i can see where it would work, just curiouse have youy ever run one of these engine after you stored it?
kerosene
not neccisarily true, i have noticed that my blazer gets better gas milage when i use lucas oil stabilizer in it, only by a mile or two per gallon but you can see a differance
Check this out...
did he state the milage? i must have missed it
Crankshaft groove, rear main seal, etc.
i just tapped gently with a hammer to keep it straight
D/R EA82 swap into AWD Auto EA82T ??
i've ridden in an xt powerd gen 1 wagon the car hauls rump roast for what it is. wouldn't be a bad swap but the wiring was a *************** from what i understand
kerosene
i know that feeling my chevy blazer was spoiled by it's previouse owner
questions on 5spd 4wd and auto 4wd
the front c/v's should fit, but not the rear diff if they are different ratios, because you would have to swap the front diff as well and the auto front diff is different. -jeff
Check this out...
i like that
Clutch cable ???
read the thread he's doing an auto to manuel swap
JY heads up in co....
if i go junking i'll let you know
Who's That Knocking On My Door???
thank you, you said what could notboy this thread is way off topic
well i'd say measure your current battery length, width, height, then but the biggest one that will fit edit: sorry stated the obviouse
