jeffast
Everything posted by jeffast
  1. i under stand that there are holes cast into the heads, prospeeder answerd my question i don't have any turbo experance i forgot the uppipe goes infront of the engine under the oil pump
  2. yes but the pump is in front not on top, am i missing somthing? edit: oh i'm tired night thanks for the lesson
  3. how is the coolant getting from the pump to the exhaust, i'm confused the exhaust goes out the back the pump is in the front are you sure it isn't a hose, do ea82's have that steel inputline with the oring that seals it?
  4. checker sell it it comes in a roll as weard as that sounds , it's a tar like stuff, i
  5. checker sell it it comes in a roll as weard as that sounds , it's a tar like stuff, i appologise if this makes no sense i'm tired
  6. chuck norris lost his virginity before his father oops that should have been .net got confused with the name change and all
  7. that's the second touring wagon i have ever seen
  8. might be a rod knock, sounds kinda like my six did when it had one can you upload an audio file?
  9. change the oxygen sensor it costs less than $30 dollars and takes 5min on a turbo it's the wire coming out of the down pipe that will help allot i got 8mpg when i did mine
  10. meh 1 cup of gas, 30 sec, less than an hour and allot of parts, i'll go the gas route first don't fix what isn't broken. if you keep fixing somthing untill it's broken you get micheal jackson ha ha i'm tired yay beer
  11. read his signature, but he has a point normally i'm against just screaming search but this topic has been coverd a few times, look for wjm and steve09man, they have the two most powerful ea82 motors i have heard of
  12. what he said but before throwing money at it i vote for just dumping fuel down the throat and seeing if it fires
  13. how loose was the passenger side belt it's sounding suspicouse to me compression test is in order
  14. +1 for pouring gas down the throat, i agree starting fluid is bad stuff unless it is very cold out
  15. i dissagree i have a 2.5 y pipe back on my xt-6 it's almost to big i lost allot of torque, just my experance your may differ, just an oppinion
  16. you will, WILL lose allot of torque if you put an exhaust ment for a turbo on an na they need a certian amount of back pressure
