Everything posted by jeffast
i have and that is a very accurate description of what happens
POLL: "Overhaulin" pick a paint scheme
jeffast replied to BeefaRu's topic in Old Gen.: 80's GL/DL/XT/Loyales...
STILL VOTING 5 HERE:headbang: -
Denver: Goin' to the J yards 7-10-06
if you come across a six let me know -
Ok please help me make a decision. I need opinions!
jeffast replied to yodannyc's topic in Old Gen.: 80's GL/DL/XT/Loyales...
fwd makes drifting in dirt boring -
you know i think mike's right
the most overpriced EA-82 ever
jeffast replied to daeron's topic in Old Gen.: 80's GL/DL/XT/Loyales...
hopnestly that was subaru dealer maybe they were trying to keep it to show how far subaru has come any one else notice it was in their showroom next to an 06 legacy? -
the cams are bad with delta cams you can get a ton of high end but you lose all the lowend power
#5 -
i second that :headbang: :headbang:
Sand Rail - time to go from VW to Subaru
jeffast replied to second skin rep's topic in Subaru Transplants
from the reading i have done plus all the stuff i have read on this board plus other rumors i'd hav to definatly vote the ea81 or the ej22 ej22 you get way more power but with the ea81 there is no electronics nothing to break no timing belts etc. however you get around double the bang for your buck with an ej22 and those things are hard to kill -
removing sheared bolt with drill bit stuck in it
jeffast replied to idosubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
where were you before i killed my head -
MEET: CO: May 21th at Red Rocks Park
jeffast replied to The Korean's topic in Meet n' Greet. Your USMB Welcome Center
russ:headbang: : did you go with a high comp block????? -
i don't know mine came right off with a breaker bar once i locked the flywheel
Ej22
jeffast replied to legacy63's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
wlecome to the board but no sorry you want the new gen forums for a legacy -
Rotors & Pads? ACDelco, Wagner, advice?
jeffast replied to BlindSight's topic in Old Gen.: 80's GL/DL/XT/Loyales...
name brand is all i'll say, rotors are hard to screw up but somehow off brands always seem to find a way to mess somthing up. no matter how simple the product -
Brat & XT6 CarbonFiber Hoods
jeffast replied to Gravityman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
that is freaking awsome -
what he said
i'd be interised in one for an xt some other people i know might also be interisted but i need to know a price before i say interisted
Carb woes+, looking for suggestions, long winded...
jeffast replied to DrKrazy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
thats a redneck carb clean out an itialian tune up is taking it out on the freeway and taking it up to or past the redline for long periods of time -
take a punch of appropriat diamater knock the roll pins out of the cv's on the diff end. then i like to undo the drive shaft and the bolts that hold the diff up there are two in back that are 14mm i believe then one above the differential that should be 19 if i remember correctly. after this beware the diff will fall but it will allow you enough movement in each direction to easily get the cv off and in the quite likly event that one side sticks i find kicking the diff with both feet dislodges it quite easily with out denting a case the way a hammer does any questions? edit: this is assuming you have the car on stands second edit: use pb blaster liberally on anything that looks rusty or has dirt on it good luck
don't go with cheap pads i work in an auto parts store go with good semimetallic pads or cheap cerimacs you will know the differance
