Everything posted by jeffast
POLL: "Overhaulin" pick a paint scheme
STILL VOTING 5 HERE:headbang:
Denver: Goin' to the J yards 7-10-06
if you come across a six let me know
Ok please help me make a decision. I need opinions!
fwd makes drifting in dirt boring
No More Boost :(
you know i think mike's right
the most overpriced EA-82 ever
hopnestly that was subaru dealer maybe they were trying to keep it to show how far subaru has come any one else notice it was in their showroom next to an 06 legacy?
reving?
the cams are bad with delta cams you can get a ton of high end but you lose all the lowend power
If in Denver, go to Summit Auto -- OMG!! (with pics)
jeffast replied to BeefaRu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmy low jaw is stuck open more pics please
#5
Ball Tearer Brumby
i second that :headbang: :headbang:
Sand Rail - time to go from VW to Subaru
from the reading i have done plus all the stuff i have read on this board plus other rumors i'd hav to definatly vote the ea81 or the ej22 ej22 you get way more power but with the ea81 there is no electronics nothing to break no timing belts etc. however you get around double the bang for your buck with an ej22 and those things are hard to kill
removing sheared bolt with drill bit stuck in it
where were you before i killed my head
MEET: CO: May 21th at Red Rocks Park
russ:headbang: : did you go with a high comp block?????
Crank pully 22mm help!
i don't know mine came right off with a breaker bar once i locked the flywheel
Ej22
jeffast replied to legacy63's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwlecome to the board but no sorry you want the new gen forums for a legacy
Rotors & Pads? ACDelco, Wagner, advice?
name brand is all i'll say, rotors are hard to screw up but somehow off brands always seem to find a way to mess somthing up. no matter how simple the product
jeffast replied to BeefaRu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthirded:headbang:
Brat & XT6 CarbonFiber Hoods
that is freaking awsome
jeffast replied to BeefaRu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsounds worthy of a visit
CF Hood Interest
what he said
CF Hood Interest
i'd be interised in one for an xt some other people i know might also be interisted but i need to know a price before i say interisted
Carb woes+, looking for suggestions, long winded...
thats a redneck carb clean out an itialian tune up is taking it out on the freeway and taking it up to or past the redline for long periods of time
Anyone with pictures of two tone paint jobs? (loyale wagons)
looks cool miles
Pulling Driveshaft
take a punch of appropriat diamater knock the roll pins out of the cv's on the diff end. then i like to undo the drive shaft and the bolts that hold the diff up there are two in back that are 14mm i believe then one above the differential that should be 19 if i remember correctly. after this beware the diff will fall but it will allow you enough movement in each direction to easily get the cv off and in the quite likly event that one side sticks i find kicking the diff with both feet dislodges it quite easily with out denting a case the way a hammer does any questions? edit: this is assuming you have the car on stands second edit: use pb blaster liberally on anything that looks rusty or has dirt on it good luck
don't go with cheap pads i work in an auto parts store go with good semimetallic pads or cheap cerimacs you will know the differance
Pulling Driveshaft
you need 2 10mm wrenches pb blaster and a 17mm to pull the drive shaft it's held in by 2 17mm bolts on the yoke the one end will slide right out of the transmission be careful not to let the end that goes to the transmission hit the concrete i reccomend setting it down carfully and wrapping it in a towel the end on the diff comes right out and takes 2 10mm wrenchs and allot of pb blaster to get off. whew any questions? edit no problem just remember to get the winsheild fixed:rolleyes:
