Everything posted by jeffast
what should my compression test at
well the title i was curiouse what compression my car should test at currently i am getting withen 5psi of 120 per cylender edit: i know this sounds stupid but i am having power issues also how far up the temp gauge does the needle ride on your car?
What glue to use?
two part apoxy any home improvement store would have it but it would be over kill ounce again
Hi All
welcome the single tap mentioned above maybe what is commonly refferd to as the tick of death it does no actual damage it is just annoying as hell it is generally caused by a bad micky mouse gasket on the oil pump sry i kind of went over board for somthing that may have nothing to do with your problem eather way welcome some one here can definatly help you
MegaSquirt....
i've been looking at mega squirt how hard was it to install? also KICK@$$
my car is no more
i agree with 91loyal try to fix it looks salvageable to me good luck whatever happens glad you weren't hurt -jeff
EA-82T valve springs? Upgrades?
my er27 seems to fall flat on it's fACE AS YOU PUT IT AROUND 7000 i would like stronger springs as well edit: lets say seven grand, i am having major engine problems at the moment
The b3stArest Intercooler evAr!
what is going on here arrgghh proof proof
Was there more than one 4-lug Suby bolt pattern?
my xt-6 has 500 hp with turbo nos and flame stickers with a 12yr old's logic the flames add a hunderd hp
Hello all, i'm new here
welcome you might look into turbo charging
Renting a tow dolly in the Seattle area
i had them screw up the destination and the pickup either way they gave me a dolly at the right place but still it was two hrs i could have been driving home wasted i drove like 7 hrs to pick up my six
burned out brake pads
my hcevy ate a rotor about six months ago the clue's it gave me for the last 500 miles of it's life were metal shavings every where loud grinding while breaking voilent tremors through the brake pedal and a mild case of nausea this had nothing to do with the brakes oh yeah those are certainly some well loved brake pads
clutch issues (but it doesn't slip)
it coult be a rivet is jamming between the pressure plate and the flywheel somthing like that happend when i bought my 6 with a badly slipping clutch i drove it two blocks and the clutch seized to the flywheel untill i replaced it
RX vs GL?
\ i wish to stronlgy appologise i love the rx it is my favorite soob next to my xt-6 what i ment was it was only available in a coup but i was wrong and i am sorry EDIT: I MEAN I NOW KNOW THAT IT WAS AVAILBLE IN A SEDAN aswell
RX vs GL?
the rx was a different body and has a really cool driveterrain i know about the setup but not enough to elaborate and give you accurate information the gl is the luxary model if i am correct but it came in three body styles if i am right a hatchback, a sedan and, a wagon. the rx is just a two door coup
My name is Earl
sweet i have to check it out now when does it air
rx coupe
pics please
COPPER HEAD GASKETS for XT6!!!!
yyyyyeeeeaaaaahhhh yyyyeeeeaaahhh fun i wish i had $3000 to spare so i could get my car ready
Car wreck :(
that totally sucks what type of car was it ?
RX Springs > XT springs
badass gottalove those rims
Ok, so...any guesses...?
could an ea82t do that? where do they max out at
- Hello
runs hot
my xt-6 had similar problems to that i pulled the raditor to discover that the prevouse owner had welded the middle of the radiator shut to stop a leak check the radiator also one of the cooling fans could be reversed that causes it to over heat at highway speeds or atleast it did on mine
85 Brat will not change gears
just for kicks you could check the clutch cable it could have stretched and broke also what turbone said first check fluid i feel smart ignore me sry stupidity strikes me later
Locked Out
get the vin off the car go to the nearest soob dealer they should be able to cut you a key at the parts counter for under $5 just incase the vin is on the top of the dash on the drivers side not to insult your intelligence just in case
what the
well my mind set is i want the better stuff so i am faster but i love to tell people what i have under the hood some *********************s just want to be faster no matter what and have no respect for the compition i
