MiniTransAm
About MiniTransAm
- Birthday 12/04/1979
Contact Methods
AIM
MiniTransAm
MSN
minitransam@hotmail.com
Website URL
http://www.myspace.com/minitransam
Yahoo
MiniTransAm
Location
Lancaster
Vehicles
1999 Outback Wagon
MiniTransAm's Achievements
Advanced Member (3/11)
10
Hey guys. Decided to replace the axles in my 99 wagon to fix that damn idle shake. That went fine but in the process my ball joints were damaged from the pickle fork. Kinda figured that would happen. So I go to replace the ball joints and you guessed it. Pinch bolt head snapped off. Yay rust! So after a valiant fight trying to drill that thing out, I gave up and got two used knuckles from the junkyard. I removed the old balljoints out of those (air hammer FTW) and am now trying to install the new ball joints. Problem is, I can't get them to go all the way in. I ruined one already by wailing on it so hard it mushroomed the stem and the castle nut would not thread in. What am I don't wrong? I'm spreading the pinch area with a chisel as far as I dare go before I feel like i'm going to crack the metal. These things are not just falling in like I have seen in some threads. I cleaned the pocket out with my dremel, not rust in there at all. There are no burrs or anything else to hang up on. I have them coated with wheel bearing grease as well to aid in installation. What am I doing wrong!!! Help!!
Wouldn't be a bad idea. You can see how your oil holds up and if you can run it longer. If you commute is mostly all highway, I can easily see modern dino oil holding up to 5000. Use a semi or full synthetic, 7500 easy. Our outback does a fair amount of hauling things in the back so I think 6500 is the magic number for me. Since I got a good report this time around, I'll probably do an analysis every 25K from now on. Just to keep tabs on things.
Well for me, I just like to see what's going on inside the engine. Higher than average numbers can indicate problems and allow you to get a handle on them earlier before they cause a major problem. For example. If I had coolant in this sample, it would allow me to look for the problem and get it fixed before something like a headgasket goes and overheats the car causing more repairs. We also did one of these on my wife's Sunfire and it showed over 3% fuel in the oil. I would have never known that had I not done the analysis. I'm still in the process of trying to figure out what the problem is. This is also good for figuring out how long you can run an oil. Or if one oil is better than another as far a wear numbers go. Also as someone stated, you can get a pump and pull a sample from a vehicle you are thinking of buying. If you get a report back that shows some problems, you just saved yourself some potential major headaches. I hardly think they are a waste.
Only problem is how obvious it is that I'm not a mechanic. The front plugs are not bad at all. But the rear ones you don't even have room to turn the thing with your fingers let alone really know if you've crossthreaded it or not. Which I hope to hell I didn't do. I have all kinds of sockets and extensions. Maybe I need to find a really thin ratchet to use. But the thought of trying to get the plug back out again makes me cringe. I almost have to do this myself now though because I'm picking up my Trans Am in about 2 hours and have to shell out $2400 for an engine rebuild
I did read that walk through a couple times just to make sure I got it right. I've done spark plug changes a bunch of times on other vehicles. Hell I even did all 8 on my trans-am. Anyone who's done those will know they aren't a walk in the park. I just plain forgot about the clearance until my ratchet smacked the frame rail. My first thought was to simply switch the direction on the ratchet and run the plug back into the head and then take the ratchet off. Only it was just touching the frame enough that I couldn't switch it. So every time I tested to see if I got it, it's just loosened even more which pushed it into the frame even harder. I got pissed and wailed on it with a hammer so now the ratchet is broke. I'll be able to turn it by hand with some vice grips now. Problem is now it's off the ramps because I had to get the garage closed. So I'll have do this from up top or try and wiggle my self in from the bottom. I was doing both plugs from the bottom since I had more room to swing the ratchet. After I get that plug back in I'll be able to drive it back up on the ramps. But at this point, It will have to wait till Saturday or later in the week. I can't touch it now. I'll probably end up setting the thing on fire. Thanks for the advice.
Should have quit while I was ahead. Got my other problem fixed, now this. I'm doing the plugs and wires on my 99 Outback with the EJ25. I got the front driver side plug done. Now I'm working on the rear driver side. Problem is, I forgot about the clearance issue and now I have the socket wrench wedged against the frame rail. I can't move it. I can't reverse it so I can run the plug back in a bit to get the socket wrench out. I need help quick! Should I disconnect the motor mounts and try to jack the motor up a bit? I wonder how subie tech's get these things out. This is almost as bad as doing plugs on my 2002 Trans Am
Just had the battery tested too. It's fine. It's got to be a battery cable. Only problem is the dealer wants over 100 bucks for both cables and they have to order it. I'd have them by Friday at the earliest. I don't see why I couldn't make my own cables from stuff they have at the parts store. Unless Subaru's are weird about resistances and things like that. I don't see why they would be though. Less resistance the better right?
If you read the original edmunds article, they just say legacy and that it will come in Outback trim like they have in the past. There's no way that's an outback. It's too low to the ground. I'm betting that's the concept for the Legacy and the outback models will be lifted up higher. And did anyone notice that little blurb at the bottom of the article about a Legacy STi??? That would be awesome. That looks pretty sweet though.
