NewKens1
About NewKens1
- Birthday 12/17/1945
Location
NewKensington
Vehicles
'99 OBW & '00 OBW
NewKens1's Achievements
Member (2/11)
11
Yesterday I changed the 4 instrument bulbs on the Baja instrument cluster. I did remove the cover for the gear shift as well since I wanted to see if there was a wiring harness for adding heated seats. BTW there wasn't. I did make a tool from a piece of schedule 40 plastic pipe to pop the clips. It worked well. I bought the bulbs from Ace hardware for $.75 each. After I buttoned everything up I discovered that the mini bulb for the cruise control was out, I guess a trip to Radio Shack is in order. Two questions. Under the drivers's seat is a black pigtail. Does anyone have an idea what it is used for? How can I post pictures to the site?
Two weeks ago I bought an 03 Baja that had bad HG. I have collected all of the parts but what type of sealant should I use for the valve covers? I am changing all of the pulleys and the belt tensioner as well as the water pump. When I removed the lower hose I noticed that someone tried to use a stop leak and there was crud in the water pump. I have a code that show that the upstream O2 sensor has a problem. Could the leaking coolant have caused this?
2 weeks ago I bought an 03 Baja. I knew that it needed HG when I purchased it. I think that I got it for a good price. I will be reading in USMB how to make my repairs
Rear Struts
NewKens1 replied to NewKens1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I'm soory that I did not mention that I have a '99 OBW. I am fairly mechanical and most of my own work. The left rear strut is leaking. The local autoparts store will loan me the spring compressor tool. Ernie -
Here in Western PA we had a real nicemix of snow, ice, then more snow. My '97 OBW went through the unplowed street without any problem. After the city plowed the ice into my driveway I spun a little. I pulled foward, then got a little run and made it through. I could use better tires, mine are more than half gone. E
