BuddhaRoadkill
Everything posted by BuddhaRoadkill
http://www.oregon.gov/ODF/TSF/docs/08docs/08_OHVGuidemap.pdf (takes a minute to load, worth it)
do a search on starters. There is an easy fix by adding a relay. Easy, but nothing less than a gift from god. Until then, pop the hood and use a coat hanger.
91 Subaru Loyale, smells like exhaust.
BuddhaRoadkill replied to jonjon11's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Um ... is the hose that hangs off the bottom of the canister supposed to connect to something? Mines just hanging there all lost and lonely. I don't see anything within reach thats missing a hose. Vent to atmosphere maybe? edit: looks like it fits into a hole on the body. Vent to Atmosphere it is! -
Just to say thanks
BuddhaRoadkill replied to OREchipmunk78's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'll second that! -
Disabling spfi ea82
BuddhaRoadkill replied to BuddhaRoadkill's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks guys. Finally got a chance to do the test and things aren't looking to bad. All cylinders topped out at around 7 turns, cylinder 1 at 190 and the other 3 200. From what I'm reading, that means I may have some worn rings but the oil puking elsewhere. ... onward to more testing! I'm guessing it's the oil pump, but I wanted to make sure the engine was worth a poo before I started throwing more time and money at the lil' beasty. Not looking foward to the timing covers, especially with the bolts spinning in place. Not sure how I'm going to attack that. :-\ (got some front end issues as well - bad hub) -
Disabling spfi ea82
Thaaaaaaats what I was looking for. Thanks a lot GD. -
When doing a compression test, what's the best way to disable the spfi? Which connectors are the right ones to disconnect and where are they located? (The only thing I know about cars I've learned from this site while torturing my loyale. My taxonomy is lacking :-\) Keeping Your Subaru Alive mentions TWO connectors located in front of the throttle body but I'm only seeing one - which I think is called the Throttle Sensor Electrical Harness (4 linear prongs). Chiltons says to disconnect the cold start valve and ALL injector connections. (Cant find a picture that tells me where the cold start valve is) Haynes doesn't even mention fuel injection, only disconnecting the high tension wire of the coil. (Thanks for letting people destroy their engines haynes) Seems like a really simple test, if I knew the names of the parts I'm looking at The only way to learn is to just jump in and do it, so any guidance ya'll can offer is greatly appreciated.
6 stud to 4 stud re drilling question
BuddhaRoadkill replied to Phizinza's topic in Subaru Retrofitting
thanks for the detailed info on redrilling. trying to attempt this without a drillpress seems illadvised. anyone in the corvallis,or area got a set of pre-drilled rims for sale? -
About to do an oil change and thought I might try something fancy instead of just the generic 10W30. Search won't take oil as a key word so even though I'm sure this has been asked a 1000^n times before, I have to ask again. Anyone found an oil that ea82's like? Synthetic? mobil 1 is on sale! Also, is there a trick to removing the oil pan? As always, Thanks for any input ya suby masters have to offer.
Broken AC belt, safe to drive?
That was the trick I needed. Quick and easy indeed. -
Any tips on this "quick and easy" job? As mentioned, I'm new at this. It seems pretty straight foward except for the engine fan. Looks like I have to remove it before I can even get to the belts. Do I need to completely remove it or does it slide in on the axle, allowing me to slip the belt around it? 92 Loyale. 1.8L EA82 spfi with AC. -
Yes, EA82 in a 92 Loyale. Thought I put that in there. Sounds like I'm good to go then. I'll poke around the intarwebs and see if I can find a how to on these belts. Sounds easier and cheaper than I thought. Thanks again for the help. -
I popped the hood to see what that funny noise was and found my ac belt arm-wrestling with my oil dipstick. Does this belt run anything else? Will driving it around without this belt do any damage to the engine? It will be about a month before I can get the time/money to deal with belts and that "learning experience" [never changed 'em myself]. Being my one and only vehicle, I would sure like to still use it. What say 'ye Subbie Gurus? Thanks for the help once again.
All the willingness in the world is useless if you don't know where to begin. I've had great luck on this board before so I'm hoping someone will take the time to give this file a listen and help me determine what the tapping sound is. It's obviously not the TOD. I'm really REALLY hoping the engine isn't toast and that I can replace/fix something before it is. History: About 400 miles ago the water pump went out and it was replaced. Radiater is full and there aren't any water spots underneath. Current: I try to religiously check the oil [cold of course]. Checked oil, was a 1/4 low, topped off and drove 100 miles up into the Cascades. Camped. Checked oil before coming home, was a 1/4 low, topped off and came home. Checked oil the next day and there was only a drop on the bottom of the dipstick. Confused, I topped it off and drove around town for about 3 days [40 miles or so]. Then the noise slowly started. Checked oil again and it was about 1/4 overfilled ?!?! Didn't think anything of it, ran some errands [20-30 miles], came home and checked these boards. Saw the dire warnings on overfilling the oil and freaked. [Drained oil to about half] I was hoping the noise would go away after I drained some oil but it's still there. It's not there directly at start up but withing a few seconds it's slowly gets louder. Sounds like a dry engine but I'm not sure how to determine a plan of attack as I'm new to this sort of stuff. Oil pump maybe? Seals/Gaskets? Other??? Thanks for any and all advice !! File on putfile: Click here to watch Engine-noise-27
Anti-Theft Device
Thank You Skip ! ! ! ! 8 months later, sure enough, the beast did exactly that. I was pulling my hair out wondering what the hell was up. Then I remembered your advice and gave it a check. To an experienced wrench, some of the most obvious problems completely boggle us just learning the in's and out's of our subby's. To you that take the time to reply and help us through the more mundane subby trouble, I tip my hat. Can't thank you enough. Seriously, the gratitude is flowing. -
Anti-Theft Device
Thanks for the help. It was something called Electro Lock spliced into the main ignition switch wire under the dash. Ripped it out, all is well in the Land of Loyale. Well, it starts anyway. -
Hey all, I got a small problem I'm hoping someone could help with. I recently bought a 92 Loyale. Turned out to be a real lemon with no end of trouble, BUT, things are looking up. The question is, it won't start due to some strange anti-theft device. I need to bypass it at the starter but can't find any good documentation on how to do this. Could someone point me to information or provide the information? As it is now, it's just sitting there so any info would be really really great. Long story short: Get car from auction. Starts fine at first then refuses too. Take it into shop, they fix and tell me it was some anti-theft device. Drive it around for a week, engine blows. Take it to specialist and they drop a used00 EA82 into it. Now the anti theft thing is back. Ughh. Please help!!! [Chiltons appears useless] Thank you so much.
The Loyale Click?
Thanks for the replies! I just bought the thing so please forgive the name transposition. [That would explain why my search wasn't yielding much , too much Pulp Fiction I guess.] Test drove fine at residential speeds. Never heard of a Loyale before, but a 92 Suby with 121k, perfect body and interior [albiet gutless], I figured I couldn't go wrong. When I opened it up and found the "tick of death", I was more than surprised. Glad to know it's common, and more importantly, fixable. The oils at 3/4's full. Nothing on the ground. There are a few "cosmetic" electrical issues, dashboard oil pressure gauge being one of them. [permanently blinking seat belt light being another]. I wasn't going to worry about the oil gauge, but it sounds like I should go ahead and fix that somehow. Perhaps I could throw a half quart of ATF into the oil, spin it up to Mary's Peak, and then do an oil change - adding sea foam? A thorough tune-up is planned once I get some time off. Man, I was freaked out there for a minute. :cool: Since I'll be doing the oil, anyone try this Purple stuff mentioned in another thread? Recomendations for an oil? [i'm assuming 10w40, correct?] Thanks again! Ya'll prevented a heart attack :-p -
It's a 92 Loyale 4WD 3AT 1.8L [H4 MFI/FI <--- what's all this mean?] At 35mph it starts a horrible ticking, at 45mph it starts going faster and 50mph and above it get so fast it becomes a hum. Any idea what it is and how I can fix it? I found this on another Forum, but I can't find the forum again Also, it idles terribly rough. It looks like a wet dog trying to dry off. Any hints there? Is it the timing that needs adjustment? [i'm handy enough with tools, just never worked on cars before] Thanks for the help!
