twofullas
Everything posted by twofullas
  1. i jacked up the front and did as setright said , a heap of bubbles came out large and small and when i turned the car off a few more went in to the over flow bottle is that normal leaving it over night to cool any other advise
  2. help !!!!!!!!!!!!!!!!!! how do you bleed air from the cooling system , i read it a few months ago but cant seem to find it . my car has the famouse water noise in the dash board i have a legacy 2.5 please help...........
  3. WER DO I START ? DO YOU JUST USE SOAPY WATER AND SQUIRT IT ON TO THE AIR LINES ETC .ARE ANY OF THE AIR LINES FIXABLE CAUSE I HAVE A LEEK ON A LINE ON THE DRIVERS SIDE LINE TO THE SOLINOID VALVE
  4. My 95 Legacy Wagon Is Losing Air From The Front Shocks Over Night And I Have To Wait About Five Mins For It To Build Up Enough Air To Be Able To Drive . I Am Looking At Removing The Suspension And Replacing It With Springs And Shocks .any Ideas
  5. i relaced the front sway bar links and bushes and she quiet as a mouse . sweet as .
  6. hi ive just had the same problem as you have discribed apart from the water leaking , i replaced the thermostate and raditor cap and bleed the air from the system , it takes ages but it wrked fine for me good luck 95 legacy 250T
  7. thanks i wil try all these things this weekend . i live in new zealand youve all been a great helpi
  8. it does it on both front wheels as i drive along the road , a slight knock in the front
  9. my 95 legacy air suspension seems to knock as i travel over slight imperfections in the road surface . its real annoying please help
  10. i have just changed the coolant in my 95 legacy , there seems to be a trickling noise behind the dash board . im sure there is air in the system . how do you bleed it from the system?
