joeo
About joeo
- Birthday 07/08/1973
Contact Methods
Website URL
http://cybrina.mine.nu
Location
Sterling, Va
Interests
Turbochargers, engine monitoring, water injection
Occupation
Software Engineer
Ezboard Name
joeo
joeo's Achievements
Member (2/11)
10
Thank you for your reply. Yes - I've read through that document, but I still cannot find the connector to use. That doc says: Enter ABS system diagnostic mode by jumpering terminal L in the ABS check connector to body ground. Check the schematic in the service manual to identify terminal L. Note: Some models have a grounding lead attached to the check connector. I don't know which one is terminal L, and I'm leary about trying to just ground those pins, and hoping for the best! Thanks for any ideas! -Joe
Hi All - been a while since I've posted. The ABS light in our 1995 Legacy Outback came on - so I came to USMB! I found the method to check the ABS codes, but my Legacy appears to be different. I was trying to check the codes using this: http://www.ultimatesubaru.org/forum/attachment.php?attachmentid=4065&d=1154383816 But my setup looks like this: I don't seem to have the diagnostic terminals - unless that's what those two green things are. I know that when connecting the two green terminals, the check engine light flashes, and it goes into some diagnostic mode, but this is different than the ABS. Anyone know how to check the codes on a 1995 Legacy Outback? I'm stumped. I also checked over by the fuses for a two terminal conenctor, but none is present. Thanks very much! -Joe http://www.lovehorsepower.com//SubaruDocs/subaru_page.htm
Olnick, and jjou812 - you're very welcome! jjou812, your 1990 Legacy should be really similar. I used to have a '90 model and it looked almost exactly the same. I bought my axle replacements from a local Autozone - hope they are OK! If it's making a noise, I would check it out, or if it's still under warrenty from Pep Boys, ask them to check it out. Good luck! http://www.lovehorsepower.com
Our 1990 Legacy Wagon has an exhaust leak where two pipes appear to come together. I'm not sure how this pipe is supposed to look? There are two flanges that are spearated, and the two bolts have springs on them. Are these flanges supposed to be pressed together? Thanks for any help! http://www.lovehorsepower.com
