Midwst
Everything posted by Midwst
part numbers?
Midwst replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Thanks for the info. Turned out to be no big deal. -
I am wondering if the previous owner damaged the crankshaft pulley. It doesn't look quite right when its turning. Someone mentioned that it can be damaged by improper removal. How can I tell if it is messed up? Will have to get a replacement from the junk yard. Hope that one isn't messed up too. Someone mentioned using 2 bolts to wedge a prybar between to hold the pulley still while removing it. Will this damage the pulley? Thanks. Oh, also, if the previous owner did mess it up, will this harm the engine in any way? 91 Legacy 2.2 non turbo
It says in the Haynes manual that I have to remove the timing belt to get to the crank sensor on a 91. Is that true? Thanks. Also, I do not have a check engine light. I think the sensor is bad because it only tests at .02 alt volts. The Haynes manual says around .10 alt volts. I assume this means its bad, but hasn't failed enough to set a code.
TOOLS NEEDED?? I'm on my way to the junk yard tomorrow. What tools do I need to get this thing out? I will bring my 3/8 ratchet, assorted extensions, 10mm socket, pocket screwdriver, prybar...plan to break timing cover... knife to cut belts. What else? Have never done this job before and don't want to be stuck out there without the right tools. Thanks.
I am considering trying a 1/2" inpact gun on my crank shaft pulley...thats the way I usually get the bolts out on other kinds of cars. I hold the pulley still with a chain wrench. Question...on the Subaru, is there room for a 1/2" gun? Do I have to remove the radiator? If so, I may try a different method. Thanks.
Ran the test on the crank & cam sensors. Cam reads about 1.47 alternating volts at cranking. But Crank sensor reads only .02 alternating Volts at cranking. This is way below what the book specs are. Called the dealer and almost fell out of my chair. $350 for the crank sensor!!!! I could buy a whole engine for that price! May have to look for a junk yard crank sensor...but it is a part that takes a lot of labor to R & R so...what do you guys think? Thanks.
If you are going to go to all the trouble to pull the axle, its actually much faster and easier to replace the axle than replace the boot. The boots not free...and there is always the chance that the clips won't hold, or it will leak. If you are replacing the tranny, I assume you plan to keep the car for a long time. Most auto parts stores offer lifetime warranty on axles, so its not wasted money. It will need to be replaced more than once anyway. I have found that if the joint is dry...not slinging greese anymore, it is already getting damaged. My front differential got messed up, along with the wheel bearing when an axle broke. Personally, I would just put an different axle in. I have had really good luck with the "A-1" brand of axles. Out here O'reilleys sells them. I mention this because some reman axles are junk. There are some cheesy 2 piece boot kits that you can use so you don't have to pull the axle. I have found them to be nothing but trouble. Thats just my opinion. Some will differ with me...just my 2 cents.
For those of you who have been following the drama, I did not get the Loyale. The dealer admitted that the car could not do 70mph. This, combined with the rust, weird engine noise, rough idle...all led me to the decision to walk away. I'd decided to put that money towards a Legacy. For anyone interested there is a 2WD gl wagon in town here for $500. Have no clue what's wrong with it except LR quarter is bashed in. Its in Iowa. If anyone is interested I can get the details, year, miles, etc. They'll probably take less than $500. Its been sitting for a while. Many thanks to everyone here for all of your help. I will miss the old generation gang.
Has anyone installed a reman transmission in their Legacy and been happy with its performance? I am looking for brands/reman companies that have trannies that can go the distance. If you had a reaman tranny put in your Legacy, automatic, please let me know how many miles you've put on the car since the reman was put in and if there have been any problems. Also, what company remanufactured the tranny.... ie: Certified, Jasper, etc. I have been in the car business long enough to know that brands matter and some reman companies suck. Thanks for the help. -Sarah
I put 2 new tires on the front of my Legacy, 9 mo ago. Rear tires are badly worn. Didn't know about the tire thing then. Tranny is tanking for other reasons, so not worried. Question, how many miles difference can one have on the tires? I've barely put any miles on the car at all since 9 mo ago....may be able to get away with adding 2 new tires to rear...plus new tranny. Hate to drop $300 for a matching set when the 2 front are so new. Second question: can mismatched tires cause a "bearing noise" in the tranny...from the differential? Thanks. -Sarah
Structurally speaking, what are the danger spots for rust on the older legacies? i am not concerned with door panels or quarter panels, but things like suspension mounting, etc. One guy told me that the rear wheel control arms mountings can rust out causing the rear wheels to spread apart! Is this true? What other things should I check for?
