raybo
About raybo
- Birthday 03/07/1950
Location
METRO BOSTON
Occupation
engineer
Vehicles
99 legacy 2.2L
raybo's Achievements
Advanced Member (3/11)
10
99 legacy wagon with 2.2 L, IDLE IS QUITE LOW, INTERIOR AND EXTERIOR LIGHTS FLICKER WHEN IDLING (no flicker when engine is off) ENGINE ALMOST STALLS OCCASIONALLY WHEN COME TO FAST STOP. Had Autozone check alternator while car running and no problem indicated. Then they checked the battery and said it was bad so replaced it for free (under warranty). Flickering and low idle are exactly the same with the new battery. Any thoughts?
have '99 2.2 liter legacy wagon with 170,000 mi. Have been using 10-30 oil. Recently noticed clicking valve sound for first few minutes of driving at beginning of day. Also a slight miss when first starting. Should I try an additive like Sea Foam or Marvel? Noticed on one blog that some 2.2 liters had problem with valve guides dropping to cause sticking.
As described earlier, I was getting wear on the inside of a front tire of 99 Legacy Wagon. The alignment guy said that the camber was one degree negative. Since the camber is not adjustable on this model he suggested using a Fastcam Bolt to adjust the camber. Its an aftermarket cam bolt which replaces the upper bolt on the strut connection. I have seen one on the web that adjusts the camber up to one degree which would be perfect for my wheel. Any thoughts on pros and cons of doing this myself?
The car does drive straight whenhands off, no shaking etc. On the older tires there was some, but less, cupping on other passenger front tire on the inner side. By the way, at this point the cupping/wear only extends in about 1/3 inch from the edge of tire. I'll try taking a picture of it when it gets a little brighter (and stops raining).
