Contact Methods
AIM
ThisRoosLifted
Yahoo
Chevyguy22
Gender
Male
Location
Tacoma, WA
Interests
Subaru's, Chevy's, Books, Snowboarding, Camping...
Occupation
Bookseller
Ezboard Name
Bratwerst
Vehicles
89 Hatch, 90 Leg, 96 Brighton (Leg)
Recent Profile Visitors
Bratwerst's Achievements
USMB is life! (4/11)
13
Rosey the Forester - My new family helper
Bratwerst replied to TheSubaruJunkie's topic in Members Rides
"Burns a little oil and makes my wife sick" - sounds like a review of my cooking... Hope you can though. Back on topic though: The work on those bumpers really cleaned it up. -
Looking good man. Can you pleeeeaaaasee come to WCSS this year?!?! Modded Subaru in your driveway = no excuse ???? -
De-Smogging - LET'S DO THIS!
Bratwerst replied to Bratwerst's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks on the HVAC - that makes sense & I'll try what you mentioned. I left the fuel delivery and canister alone as they actually serve a clear funtion. It was this crap I wanted gone. That table is all stuff I removed and the engine only runs better! -
EA81's went up to 87 with brats & 89 with hatchbacks. It's a cool little car -
I tore into it today and elimated a ton of crap - some of it clearly faulty. My throttle response has also gotten much closer to what I think it should be. Anyone know what that single small vacuum line that goes through the passenger side firewall is? Looks like it goes into the area behind the glovebox. To be safe I kept it hooked up to the manifold vacuum but eliminated the little switch dealy that it went through. Thanks for the responses -
I'm not looking to do any swap actually. If I'm swapping anything it will be the EJ22 sitting on the garage floor... later on when I've got more time/space. Buying a whole setup will cost money plus there's waiting for one to surface. I've had a brat with a stripped down Hitachi that ran great & strong for years. I've also had a weber on my lifted wagon but that's another $250. Eliminating this oddball emissions stuff will cost practically nothing and will tell me if there is something up with the carb (then I'll drop the $$$ on a Weber) Thanks for the post either way, spfi's are nice. -
I finally found one blurry-as-crap picture of my old engine that helps out significantly. What is shown is precisely what I'm trying to replicate. I also found a picture from when I was swappng from Old-Nasty to new, not helpful but I think it's worth sharing. -
Here's the rest of the pictures - like the strange little switch on the pass. side of the manifold that hooks up to the metal emissions tube branching off the exhaust via a lone vac. line. -
First off, vehicle is an 89 EA-81 Hatch that must have originally been from California. SO MANY HOSES!!! Now that is past the emissions exempt date I will no longer need to pass emissions. She's not running how she should and with all of these hoses, canisters, filters, switches, and who knows what else it's hard to troubleshoot my lag in throttle response. About 10 years ago I de-smogged an 83 EA-81 BRAT and it purred after I sorted it out. However, that was 10 years ago and I cannot remember what systems were vital to basic operation. So here's what I'm asking: Which of these hoses/canisters/switches that I have labeled are essential? I know I need the EGR, Vac line for the Disty, and the Vac. actuated secondaries for the carb. So here are the pics to make things as clear as possible. Thanks for reading... also if anyone has a picture of thier stripped down hitachi manifold or a picture of my old BRAT's that would be very helpful.
EA82 axle measurements??
Thanks again jerry - not what I wanted to hear - but it's what I needed to know. - Erik - Tacoma, WA - -
whoops - front - but rear would also be good to know. -
Can someone measure an EA82/Loyale Axle for me really quick - end to end - pretty pleaaaaaase?? - I'm trying to compare EA-81 and EA-82 axle lengths - Erik - Tacoma, WA -
Evans Creek today in the imp, took 311 alone...
Bratwerst replied to Ratty2Austin's topic in Off Road
People still up there? I dont' get off of work until 1'ish - 12:30 if I'm lucky. Even worth comming up at that point? If anyone can give me a call to let me know whats going on that'd be even better (253) 278-6694 **this number is for today only!*** thanks - - Erik - Tacoma, WA - -
On my cars I've always changed the pads before this happened - The previous owner of this car wore the pads down to the backing plate. Now the piston is giving WAY more resistance to being screwed back in than all the other subarus I've done this on. At this point (piston waaaay out) do I have to take apart the caliper - or do you think relieving the brake pressure via the bleeder screw would help, then follow normal procedure? (btw - I already removed the M/C cap to help a little bit with the pressure issue) Thanks in advance - - Erik - Tacoma, WA -
