Location
san marcos
gyuunuuya's Achievements
Advanced Member (3/11)
10
Yeah but if my TPS is inverted then at fully open it should be at 0-0.5 volts. Mine isn't full open it's at 2.8 volts. But your saying it doesn't matter what sytle of TPS I have but if the car came stock with a TPS that at closed was sitting at 0-0.5 volts and was replaced with a TPS that at closed sits at 4.5-5.0 volts it would seem that would definetly make the computer a little confised. Unless someone here knows for sure that the computer will automatically adust for a change like that it seems I need to a. Find out what kind of TPS came stock with that car. b. Get a new TPS that at fully closed sits at 0-0.5 volts. and at fully open sits at 4.5-5.0 volts or inverse depending on what kind of unit I need. I could check the sweep this weekend to see if it's dropping signal but it still doesn't change the fact the unit isn't operating properly already from the tests I've run.
Ok I tried testing out the TPS wires by rotating them in my hands, and seeing if there was a short of any kind = no difference. I followed the wires to the harness and cleaned that up = no difference. Came back to this board and did some searching on TPS = didn't find much. Thought about it with my feeble mind a little bit I remembered one thing. The TPS was marked with white crayon at screw positon, which means some mechanic worked on it and either replaced or removed the TPS at some point. The QUESTION: What would happen on a subaru if the original TPS was a non inverted TPS and it was replaced by an inverted TPS????? Since the TPS is working correctly and I don't really see a problem with the circuit I'm hopeing that an inverted TPS would screw up a car built for a non inverted TPS. Thanks in advance.
Wow thanks alot Gary hopefully I won't screw up mine. I will try to do that tonight when i get home. Does the TPS have it's own connector to the ECU? Hopefully it will be somewhat obvious when I try the rolling trick tonight. I have a butt connector set and crimpers so if I do find faulty wiring I will be able to fix it on the spot
Yes Nipper I replaced the CTS as well as the sending unit underneath it. I cleared the codes yesterday after I got home from work, as well as retarding the TPS back to 4.8volts. I will check the car when I get home to se what codes it's throwing out now. Thanks again guys I will definetly keep you posted.
