Chongo
Contact Methods
Website URL
http://
Location
Manassas VA
Chongo's Achievements
Advanced Member (3/11)
10
General 86 GL wagon problems...***FIXED***
Chongo replied to theDirtyRue's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Good luck, it's probably the radiator imop, replaced mine with a generic one and now it runs real cool, If you want my '86 GL wagon 4WD 5 Spd GL EA82 1.8 (177K) you can drive out here and use it for parts, I can't even seem to give it to charity and no one is interested in it here at USMB...stilll runs great but needs an engine re-seal and a few other things..........East Coasters????????? -
Blue Book Value '86GL Wagon??
Chongo replied to Chongo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Meeky, if I can get more off my taxes from donating this I might go that way. It's got brand new front tires, I just put brand new rear shoes on the rear and had the drums turned, exhaust is brand new from Y pipe back, Y pipe needs some spot welding where I installed a sleeve to make up for some after market imperfections. The engine has a new water pump, timing belts cam seals, but it leaks oil where the heads meet the block, hence the re-seal. Hitachi was rebuilt about 2 years ago. It flunked inspection by a nit picky dude by the same garage that has always done what work on it I couldn't do, I'm so piss*d. My son took it in for inspection instead of me so maybe that's why he cited a "loose steering column", funny there was no problem with it the year before, in addition to a leaky exhaust, rear wheel cylinder leak (residual brake cleaner fluid) and a "loose connection at the front strut and spindle"?????? They were the same guys that replaced all the bearings on that side months ago. So, I'm not dealing with garage any more to say the least. If you can deal with a leaky engine and spot weld the Y pipe this car should pass safety and emmisions, though you might not need emmissions in Ruckersville. Frame rails holes are another story. I would want more than 100 bucks for it, maybe 300, bring a set of tags and you can keep the new interstate battery in it too..........Let me know -
Regretfully, I must part with my 1.8 EA82 GL Wagon 4WD 5spd. I posted it in the "for sale " Forum but only got one reply. It needs an engine re-seal, some exhaust work, some front end work and some frame rail restoration. It's got 177k miles, but I dont want to throw any more $ in it as I'm now restoring a '71 VW Camper. I really hate to part with it, it's been a great car and I would prefer to see someone in the USMB family take it off my hands. My only other option is to donate it to charity, which is the reason for this posting. What is the blue book value of my SOOB?
Send me an email and I'll return some pictures of mine, the '86 GL Wagon that's still in my driveway for sale or part out......I've never been able to figure out how to post pictures here but can attach plenty via email ......... Chongo . You were the only one that replied to my posting weeks ago
Should I part it out or spend some $ ?
My tags and registration expire Oct 31, can't get it re-newed without a pass on the emissions. The Soob is in my driveway and will stay there till I either get it fixed or decide to part it out....Once inside the garage I'm either gonna fix it or tear it apart.......I'm so bummed out, what a great little vehicle these Soobies R -
Great replies from all, thanks very much, still have yet to hear from the East Coast Bunch or am I missing something??? Looks like I'll part this one out and get me another SOOB............ -
Ok all you East Coasters (or any of the rest of this great forum), my 86GL Wagon 4WD EA82 is on its last leg....Engine has 177k and needs a re-seal badly, timing belts, cam seals and a new water pump just months ago, but it still leaks around the heads at the block. Hitachi needs either another rebuild or a new one whatever, exhaust is real stinky. Frame rails where they curve up underneath at front suspension have major rust holes. Needs a new alternator for sure. I need to get my Y pipe re-welded, the place I ordered it from sent me one that was about 3mm short of clearing the studs on the heads so I it shortened it and had it re-welded but the guy missed a spot here and there on the sleeve so it leaks. The inspection dude that flunked me cited me for a leaky Y pipe, ok I can deal with that, leaky wheel cylinders in the rear end (funny I just replaced the rear shoes so it would pass for that and saw no leaks whatsoever, must have been all the brake cleaner I sprayed on everything) and a loose steering column, but it passed the year before with the same condition at the same place! Then this dude said "Left front strut at spindle loose" What???? I love this car to death and really enjoy being part of the SOOB bunch and met a lot of great folks at Carlisle in May and want to continue on with this wonderful band of maniacs that are enthralled with this devotion to the Subaru. What's a Soobie owner to do????
Push button 4WD and intro
Chongo replied to diluded000's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My '85 Jeep Cherokee did the same stupid stuff with the vaccuum actuator, guess this was the way most car maunfacturers did the 4WD push button or move a lever deal to engage or disengage the 4WD. My '86 Wagon has the "Shift into neutral at about 15-20 MPH with the clutch in and yank the lever up for 4H or 4L" deal...boy I like it mutch better.........Good luck on the shifting dude -
Probably lots of mold and mildew inside the area of your heater core A/C fins inside the dash.......U gotta take it apart and spray it down with cleaner you can get just for that purpose.........Good luck!!!!!! P.S. Does your drain tube drip properly after running the A/C???? If not then the line is clogged adding to the problem you now have........
really odd smoking problem
Chongo replied to dave valiant's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My '86 GL Wagon 4WD 5 spd did the same thing when exiting off the highway on a long loop and then entering a straight stretch....upon accelerating a big cloud of blue smoke would appear and then go away.......Had the Hitachi carb rebuilt and that took care of the problem.......like the carb was dumping fuel due to centrifical force around that long downward loop on the exit ramp.....hope this is another thing to consider......... -
1987 Subaru GL10 Wagon (Should I Buy)
Chongo replied to harrellee's topic in Old Gen.: 80's GL/DL/XT/Loyales...
BUY IT BUY IT BUY IT!!!!!!!! You will really like it a whole lot. Go to the events section of this forum and look at the Carlisle Show pictures from this past May. There were a few wagons there, mine included (the brown '86 GL). 575 is a great buy........Come on up to the show next year its a real gas!!!! -
Pictures from CV axle replacement work.
Chongo replied to MPVSubaru87's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Awesome pictures, now I feel confident in trying this myself, as much as my '86 GL Wagon has eaten up shafts over the years....Thanks to all!!!! Carlisle RULED!!!! We need more East Coasters there next MAY!!!!!!!! -
I've decided to take out the A/C for various reasons 1. I never use it 2. I never should have replaced it with R134 without changing the dryer 3. It robs my old 166K mile engine of power 4. needs to come out anyway when and if I do a rebuild Any advice on removing the compressor and the different belts needed would be appreciated P.S. Carlisle RULED!!!!! Can't wait till next year!
Is this wheel bearing noise?
Chongo replied to Flakrabbit's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check your ball joint seals too......If cracked and losing grease, you otta replace them....Check all suspension bushings as well......Check you rack and pinion steering boots for cracks and seperations......all this stuff comes apart at the same time so if you take it to a shop instead of doing it yourself, get it all done at the same time, will save you lots in labor. Have you figured out which side the noise is coming from??? Take a passenger with you if you're not sure and listen to the noise.....There were some really nice Brats at Carlisle PA, especially SUBARUBRAT........This man KNOWS the Brat........Check out the Meet and Greet site on this Forum and look for the "Carlisle" posting, and you'll see some great pictures of us at the show....some really nice Brats were there.......
