ej.swap.radiator woes.
You guys nailed it.......if only I had read your solutions in time. Replaced thermostat, same situation. Took off upper hose and dry as bone. So decided to fill from upper hose......worked perfectly. Never had to do that before. Thanks for the tips.
No on the hose. Cant imagine a clog, will tear apart and find out.
Ok, so I switched out my old leaky radiator which did not overheat for a brand new one from rock auto.....and now I overheat! The coolant is not circulating through the system. Motor heats / overheats yet heater does not blow hot. I know coolant is not circulating because there is no coolant in upper hose when I take it off the engine. I have tried to bleed the system but llevel does not go down when I fill radiator and I know the system is not full because I drained about 1.5 gallons of coolant before I took the old one out and the new one will only take about 1/2 gal. I have replaced several radiators on gl /beats and never had this problem. Suggestions? I should have let the old bugger alone.
EJ swap radiator
Hey gd, good to hear from you. How much does your shop charge for the work?
EJ swap radiator
Ok, I can find flex hose or dual diameter, but I cannot find both in the same hose. Anyone have part #'s or know who carries these? Thanks
EJ swap radiator
Radiator arrived yesterday. Going to search for hoses today. Are they hard to find?
EJ swap radiator
Need to do something with my 84 GL EJ swap radiator. Recore is $100, reman from internet is $130. Any opinions either way? If I do order new from internet, should I stick w/ GL or go with EJ22 radiator?
Remake of Vintage Subaru BRAT shirt
Poop, I'm in for one Large, I think a manilla/eggshell would look great.
Ok, let's be honest, which one of you did this :)
Sweet rally wing!
Coming to WCSS? What are you bringing?
I need the drivers side turn signal unit if you have one. Let me know. thanks
- Ea81 4wd wagon new to me!
You may ditch the PTC and keep the Subaru.- Convoy from Portland to WCSS13 (details)
I'll be heading over on Sat, bummer.- Pacific Powertrain
Do you have a way to attach a subaru engine to a velvet drive transmission? I always thought a subaru motor would be more efficient than my ford V8.- Convoy from Portland to WCSS13 (details)
Fri or Sat departure? - Ea81 4wd wagon new to me!
