About subyroo
- Birthday 08/01/1952
Contact Methods
Website URL
http://
Location
Caloundra - Australia
Interests
Suabru's - PC's - Golf
Occupation
Retired
Biography
Like to joke and have fun. Love my MY03 XS Forester.
subyroo's Achievements
Advanced Member (3/11)
10
G'day fella's, I haven't been here for a long, long, long while, I feel like a Newbie. Just checked my log in = 03-20-2006 :eek: I wonder if this vibration (shudder?) problem is what is also plaguing the Diesel Forester here in Australia, although some of their problems appear to be slight incline related but some are starting to get the problem on the flat as well. I have read of one guy already bailing out of his Diesel and got himself into an XT Forester instead. http://www.ausubaru.com/forum/showthread.php?t=18766 The Diesel Forester out here is also having DPF problems.
75,000kms or 46600 miles, weather makes no difference hot/cold or wet/dry it still rattles, it's going into a Dealer next Monday 03/20/06 for an assessment and same day replacement if found to be faulty. I'll report back here on the outcome. Do you guys have any TSB's over there in relation to this problem by any chance?
Has anybody heard of or experienced this problem with the Forester's composite flywheel? Mine rattles it's head off when letting the clutch out in 1st gear, it is going in for assessment by the dealer next Monday for a Warranty Claim. I get my Suby serviced by an Authorised Subaru Service Centre but they cannot do Warranty work it has to be through a dealer.
Problem solved............ I was having a problem with a foul odour coming from my vents NON A/C air coming through the vents, the smell was something like stale sweaty body odour. I read about a similar problem on another Forum and somebody said to pour Lysol down the air vent inlet below the bottom edge of the windscreen. I had never heard of Lysol before but it gave me a better idea, I used good ol' Aussie Eucalyptus Oil mixed in hot water to help release the odour and make it stronger. Whooppeeeeee! it worked a treat (so far ) and it also flushed out a heap of black sooty gunk which I can only put down to being road grime that had got into the vents from rainy days or being flicked up by the tyres and getting in behind the plastic protectors inside the R/H guard ( that's where the gunk came from). NOTE: Eucalyptus Oil also has the benefit of being able to remove sticky substances like label glue & chewing gum so it works well in removing road grime, however, undiluted Eucalyptus Oil also has the ability to soften or melt some plastics so be careful and remember: if a little bit works wonders a whole will not get you any better result. I will keep my nose on this one over the remainder of this week and report back for other Forum members who may run across this same problem later on. I am not sure if our International friends have access to Aussie Eucalyptus Oil but I am sure they would have an equivalent ie Pine Oil - Lysol etc.
Over this past week I have noticed a foul odour (dirty sweaty body smell) coming through all the air vents on start up and whilst running. (My fan is set on #2 and the vents are set to face level all the time) I pulled the glove box out today and checked the Cabin Filter as per http://www.scoobymods.com/forums/showthread.php?t=2109 after getting everything out, I opened up the hatch to check the filter and found the slot empty - NO FILTER. I then tried spraying some NILODOR into the fan/blower area and then running it on high, this had no effect either. I have a theory but don't want to go there really but I feel I will have to get to the root of the problem. I think that the fins on the evaporator of the A/C have collected lint and dust and it gets damp from the A/C and then as it dries out, it begins to rot and this causes the foul odour. Has anybody come across this odour or read about other Forester - Subaru owners experiencing the same odour problem?
