Everything posted by Jerry DeMoss
Welcome . Good looking subie. Got to get some bfg mtr's on that thing and go tear up some mud. I am not as familiar with your neck of the woods but I grew up in soldotna. If you are ever down towards anchor point or ninilchik on the kenai peninsula be sure to go try the trails in the caribou hills. They are a blast.
I have seen some water pumps survive on those up to around 200,000 miles. Also do the timing belt on that engine just like doing an ej22. They aren't too prone to head gasket failure compared to the ej251. They do quite well if you put some coolant conditioner in the system and keep the coolant fresh.
Question about EA-81 engines
Jerry DeMoss replied to Subieguy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Basically '83.5 or '84 to '88 on the U.S. spec cars. -
The only advise I can really give you on your ea82t heads is to be careful and not take too much material away from the ports as the head castings are rather thin compared to other subaru's. The best thing you could do is to match the heads to the gaskets and take only as much away as needed and blend the port to the gasket matched portion. Good luck:)
front LSD for my RX is it possible?
Jerry DeMoss replied to vagen's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes, the most common one people have used is the phantom grip one. I think that is the correct name? -
Ok so i just put Outback struts on my 91 wagon
Jerry DeMoss replied to SuperRallyRoo's topic in Subaru Retrofitting
I have forester struts on my '92 leggy sedan and I don't have any issues with axles but I as well had to disconnect the sway bar to get them shoe horned in there. -
To clean tools at home I use either a combination of the gojo pumice hand cleaner and old tooth brush or carb or brake clean on wrenches ect. Then douse them quick with really hot water and wipe them dry with a cloth or blow them off with the air nozzle.
More useful info can be found on some of the home built aircraft sites if you search for ej22 conversions for aircraft. There are a few people that will comment on the specifics of everything on here. Also on a side note, napa and a couple other auto parts stores can still get remanned distributors for those.
Winterforce Tires
Jerry DeMoss replied to The Dude Abides's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I never used them offroad but I put them on my wifes vw jetta when she used to drive that in the winter. Good tires, no complaints. -
EA81 Pics and video. First snow of the year!!
Jerry DeMoss replied to pwjm's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I like the chaser decals you have on your doors and rear hatch.(We never got them badged that way here.) Those are terrific fun in the snow I agree. Good pictures. -
82 subaru gl ideas?????
Jerry DeMoss replied to creswellhick's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I think it has promise. Make sure you use some duct tape in there somewhere. -
Carb E82 rebuilt and wont start!
Jerry DeMoss replied to backcountrycrui's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Definately start at making sure the timing belts are set up proper on that engine. There are 2 on that engine and they are easy to get mixed up if you aren't familiar with it. Also the carb on those isn't the best. You would be wise to eventually put a weber on there if you got the car. -
Oil pressure is probably a bad sending unit. The ea81's aren't hard to rebuild but they can be a little tricky. Your car just needs a good once over it sounds like. Good thing is that parts and bearings ect aren't that expensive for that engine.
Introduction for a long time member
Jerry DeMoss replied to Splinter's topic in Meet n' Greet. Your USMB Welcome Center
Nice cars! Welcome. -
WOW Jerry! Now you have my complete attention!
So how fast was I going?
Jerry DeMoss replied to SuperchargedRS's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Your cable that goes to the trans from your gauge is most likely sticking. Yes it is mechanical and may need to be greased a bit. -
So glad to find this forum
Jerry DeMoss replied to Kwhistle's topic in Meet n' Greet. Your USMB Welcome Center
Welcome. I am sure you will find a wealth of knowledge here as I have found. Again welcome. -
EA81 Alternator ( plane )
Jerry DeMoss replied to carl_stg's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I don't have any diagrams but you should be getting more voltage from the alternator to charge the battery properly. Around 12.5v to 13.5 is pretty normal for charging. -
Nice pictures guys! Looks like you have "real" mud there.
