Everything posted by Jerry DeMoss
Those with 1100,1300,and 1400 engines
Jerry DeMoss replied to moosens's topic in Historic Subaru Forum: 50's thru 70's
Any ea71 dual carbs? Any other rare engines? -
I don't think the adapter will work, well that depends on what motor you are planning on putting it on.Also a good place to get weber stuff is places like redline ect. They have all that adapter and gasket stuff on hand fairly readily.
Man that is a great fit with that ej20h in the spot of the ea motor! Fantastic and I am awaiting more info. Very well done indeed!
Weber install: backfire from intake.
Jerry DeMoss replied to TheYeti's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I am pointing at the brake booster as Skip said. I think that could have something to do with it. The brake master cylinder needs to be replaced because the brakes aren't working properly. Hopefully this is the problem with Yeti's car. -
95 tacoma 4x4 VS 80's Dodge Cummins turbo diesel 4x4
Jerry DeMoss replied to Uberoo's topic in Non-Soob Off Roading
I like the toyotas as a personal preference on the trucks, the cummins allthough a good motor has some problems with the front hubs. They tend to go through them. Just a personal opinion. -
Trans and Diff Fluid.... What Kind
Jerry DeMoss replied to 2K4 STI's topic in Old Gen.: 80's GL/DL/XT/Loyales...
In my hatch I am using royal purple syncromax in the transmission and the rp sythetic 75 90w oil in the lsd with the bg lsd addative. I have had no troubles with either the trans or rear diff with lsd for several thousand miles. -
Both rear tires will turn in the same direction when you are rotating one side. Otherwise the other side may turn but in the opposite direction on the non lsd unit.
Weber on the 1600.
Jerry DeMoss replied to TheSubaruJunkie's topic in Historic Subaru Forum: 50's thru 70's
I don't think that will be a problem either. You are at sea level so you will have it even easier. -
Weber on the 1600.
Should be no problem there compared to the ea81. Jetting might be just a little leaner from it being a slightly smaller displacement. -
Ea81t as core for n/a rebuild
Jerry DeMoss replied to ihscout54's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I am sure there are plenty of guys and gals on here that would trade you a decent ea81 na motor for your ea81t motor if you choose. -
As far as I know they are the same block with a different cam and dished pistons. I am not sure if the combustion chambers are really different cc's wise but they may be a little bit different. -
Sweet! Good luck man! I would love to see that thing in action.
Brought the RX home today...
Jerry DeMoss replied to milestoempty's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Nice one! Make it fun and reliable and you will love it. -
What's a good NGK plug for the EA82??
Jerry DeMoss replied to TheLoyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ngk v power is what they meant. Not sure if that really helps over the good old standard ngk plug as said above. Can't go wrong with ngk. That is what I have been running in all of the cars I work on from Jeeps to subies to vw's. -
Off Roading Venture w/ pics and a few ???s (56k beware)
Jerry DeMoss replied to Gyoas759's topic in Off Road
Gotta take that sway bar outta there. Mines still drives around town just fine without it and I am glad that is one less peice to worry about. -
Yep they fit. There have been a few people that have talked about those before on here. I am sure there is a bit of info on setting them up with mega squirt or something like that.
My $4.00 + Shipping Ebay Find
Jerry DeMoss replied to GLCraig's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Those rotors along with a set of decent pads and stainless steel brake lines you will have one of the best stopping 4 lug ea cars around! I hope those are going on some sort of rally/ play subie? -
Subaru Sambar - UPDATE!
Jerry DeMoss replied to Hodaka Rider's topic in Old Gen.: 80's GL/DL/XT/Loyales...
When I used to work at a fish canery in Alaska they used those quite a bit to haul things around on the docks. Never drove one though. -
So those fit a ea81 car? That is pretty sweet!
