Everything posted by Jerry DeMoss
Denver mad scientists - transmission lab: Lab ingredients/forumula FOUND!
I am ready to get my hands dirty! Let me know what I can do.I am a pretty good junkyard rat so let me know if I need to look for anything in particular.I am excited!
Alternator wiring ej22 in ea body
Is there a slim chance that the pulley size may be different causing it to not turn fast enough to create voltage?I may sound like an idiot but it was just a thought.
Pics from the Colorado Old School Meet!
Glad you made it back safely.Sounds like a fun drive back.Thanks for coming to the meet.Took some major dedication to make it here.Glad I was able to meet ya.
Courtneys motor swap mess thread.
Jerry DeMoss replied to SuBrat84's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would check the coil pack.I have heard of those going bad.Not very possible that the t-belts are on wrong if installed by CCR.They probly do those so often they could do it in their sleep.Check your grounds,check your plug wires,and your coil.Most likely you have something electrical.Good luck.
Questions-
I would check your cam seals and front crank seal.Those 3 seals would be wise to replace when doing timing belts,and that may solve your oil leak.The other main one I would replace would be your valve cover gaskets.Those usually are the first things that will need replacing. As far as your pugs go.Those are 14" alloys IIRC.
I see you little wagon!
I think it is kinda exciting to find stuff like that.I usually start to smile and then do a double take and then go take a look.Kinda makes your whole day.I know that may sound pretty dumb but I guess still fun just the same.
steel vacuum lines under the manifold..easy removal?
Agreed.I noticed that as well when working on either manifold.Ea81 definately needs to be pulled.
Window Tinter in CO
Jerry DeMoss replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSunfree window tinting is a good high quality shop that won't charge you an arm and a leg.They have several locations around the denver area.
a few mud pics...
Looks great! Did you go through any low hanging trees?Noticed the lights on your rollbar are a little off kilter.
ok heres the info and questions
An hour maybe 2 depending on if you have done it before.Light enough to lift it out yourself or have a friend help.
Timber Ridge Trail Ride - Sept. 22-24, 2006 (western Iowa)
Yes! Muddy!
I had a great time as well!That little parking lot ended up being alot cooler than expected!
Colorado Xmas Tree Run
I am game!We got a fake tree so I don't think I will need one but I would love to pile some trees on top just for the fun of it!
Old School Meet! Wyoming/Colorado guys and gals! Sept. 23rd, 2006
Thanks again to everyone for showing up!I really wanted to thank Keith for letting us all congregate over there and big thanks to your wife for putting up with all the subaru nuts.I think it turned out well and really couldn't have gone better.Thanks again guys for a great time! And a special thanks to Keith again for a nice ride in PC again.
Engine making a clicking sound!
Jerry DeMoss replied to BSOD2600's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI agree.Either Marvel or go with some seafoam.Pour either in your oil.The only down side is that after running it you will need to change your oil again.
This Might Be a Repeat
Thats pretty cool.I don't recall seeing that one.That would be a pretty powerfull little plane.Probly could hang it on the prop a little.Nice ROC I am sure.
Painting the hatch, need some suggestions....
I really think you should leave your hatch white.I love the way the white hatch's look.The only thing I would do is try to get some srx decals made up and put those on there,and get your rims powder coated white or gold.But that is just me.
I can see that you will probly be building a pull behind BBQ pit soon enough with some offroad tires on it! Just kidding. You will get the hang of welding soon enough.Exhaust is one of the harder things to weld anyway.Did you get a stick or wire feed?
3.9 transmission question
Rx transmission.
Fuel Smell when tank is above 3/4??
Jerry DeMoss replied to RallyKeith's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would recomend checking your fuel tanks evap canister.I am not sure if that is the correct name for it but it collects excess gas vapor from the tank.Over time I know they can get old and may need to get a new one.I am not 100% sure that is your fix but I have found that to be the case in quite a few vehicles with the same symtoms.Good luck.
Well being from Alaska I don't think that the cold weather will scare me off. Just kidding,but ya I will be there.
I think you carb needs some tlc.I would recomend checking the accelerator pump and completely go through the carb and replace the needle and seat as well as all of the gaskets and O-rings.Souns like it may have been sitting for a while and needs a little going over.
EA81 hatch WRX conversion
Ya my mistake on that!Doi!I was thinking of the EJ ones!
Sorry to hear about the rx!Well you can count me in for a couple 12packs of pop and I will bring some turkey burgers(dozen).I will bring buns too along with macaroni salad.
carb rebuilders
Check with CCR.They do great work in all that they do.I know they do rebuild your carbs(the right way). http://www.ccrengines.com/
