Everything posted by Jerry DeMoss
How the F*@# do U get the Hub Nut off??
Jerry DeMoss replied to Bucky92's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ya!That stuff works wonders!Especially usefull when at the junkyard and dealing with an old stuck on bolt or nut.I use that all the time. -
My car has an unfriendly tenant
Jerry DeMoss replied to bgd73's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I had a black widow that called my suby home.I was underneath my car cleaning it(prep for undercoating)when a big black widow crawled out from under the front fender rock guard.Jumped onto my hand and started up my arm. Oh I killed right then and made sure to flick it off real quick so it couldn't bite me!:-\ -
Suberdave's Pics
Jerry DeMoss replied to suberdave's topic in Meet n' Greet. Your USMB Welcome Center
Nice pictures man! That mud rocks! Looks like it would be addicting. -
Tom there are 2 '78 brats over at pull n save on the back row.You could pull it from either.Let me know if ya need a hand.
First pics from WCSS8
Jerry DeMoss replied to edrach's topic in Meet n' Greet. Your USMB Welcome Center
Nice picture Ed.Looks like great weather too!I will have to make it out there sometime. -
Dang thats not too far from where I work I will have to keep an eye out for it.I would love to see one.
That rig will be sweet Scott!What size tires and lift size ect are you planning on using?Also I hope you will have some antlers off of a deer on the front hood to plow trees out of the way. Just kidding.I really can't wait to see it under way.
Nice pictures.Looks like a nice trail too!Nice job!
Duplicolor makes some good stuff.I like their hight temp stuff(rated at over 1000deg F)Just use their high tem primer and then the high temp color you choose.Then if you want you can hit it with some high temp clear.I have done this on ea81 valve covers and oil pans and it seems to be pretty durable.I would just recomend scuffing the surface up with steel wool or a green scotchbrite pad prior to paint.
I have my rear diff apart since I am doing the lsd swap to 3.9.Just wondered if there is another option for the rear tapered bearings inside the diff other than a dealer item.The bearings on the LSD unit are not worn or showing excessive play,but I thought it might be worth my time to change them out.I was quoted $80 each per side for them! Maybe I am a cheapskate but I was planning on only spending maybe $40 for both.BTW I am redoing the seals also.Thanks
Make sure you have enough fluid in the master cylinder.Also bleed the front brakes also just to be sure.I had to do the same thing when I did my conversion.
1986 GL 4x4 DR Wagon Good Deal?
Jerry DeMoss replied to jeffx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sounds good.Depending on miles you may want to weasel on down towards the 500-600 dollar range. -
What is "highest mileage" world record?
A little tricky especially on a hill,but can be done especially if you are fast. -
I am pretty sure this doesn't top it but when I lived in Alaska a guy I heard of had 550,000 on his ea81 wagon.Never a rebuild just rebuild oil pump and water pump and kept on going. -
This evening while traveling on kipling right around oak street I spotted a very nice looking yellow '74 or '75 2dr coupe at the stop light.Really looked like someone loved it and took care of it.Anyone seen the same car?I just wanted to give the owner a big thumbs up! I really have been paying more attention that I used to on the Gen 1's.Really want to own one some day. (BTW-The year of the car I am only guessing.)
Greeting Fairbanks!!!
Jerry DeMoss replied to Rolloverbratboy's topic in Meet n' Greet. Your USMB Welcome Center
Thats exactly right.A friend of mine worked up there this summer and said it was pretty scorchin' hot.I know for a fact that the winters are alot of -30 to -40deg F. -
There is alot of good pictures on that site!Wish there was an srx hatch in there too.Man that brat has such a nice paint job!
I've been inducted into another forum
Jerry DeMoss replied to LUVMYBRAT's topic in Historic Subaru Forum: 50's thru 70's
Nice job! What size Jackmans are those?I know Mick was looking for a couple of 14" ones if that is what they are.Nice that it came with a spare engine too! -
What to offer..80 Brat
Jerry DeMoss replied to DrKrazy's topic in Historic Subaru Forum: 50's thru 70's
Probly the highest I would go is 600 cash since you said he advertised it for 800.I think 500-600 would be reasonable.I think it is a good idea to save that one if you can.I also may be getting a welder soon so I could help you there. -
I would go over there again and look closely at where they cut it.There have been a couple gen 1 brats at pns lately and if there is enough metal left on there to weld on to it I think it's worth it saving and just cutting the rear area off of another brat. I really thought it looked nice and I would probly settle between 350-400 if he could work with you.I would just emphasise on the fact that you will have to do alot of work to get the brakes right and also to weld in a new piece in the back.See if that works.I will help push it back over to your house if you get it.Also I have a set of gen1 alloys that I will give you if you get that one. -
Pics of my new Brat
Jerry DeMoss replied to GoldDiggerRoo's topic in Historic Subaru Forum: 50's thru 70's
Looks well worth it!Nice score! -
Engine #2... done I think
Jerry DeMoss replied to Caboobaroo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Man,thats too bad!I was really hoping to see a smokin' ea82t.I think the EJ22 na would be a good choice and plenty of power.But what about a ej22t?Still can get reliable power in the mid 200's.
