Everything posted by Jerry DeMoss
EA81 dual weber info needed....
Jerry DeMoss replied to Jerry DeMoss's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ya if you can build a couple I would be very interested.Let me know what you could do.Thanks -
Thanks Mick. I have some tricks up my sleeve. -
Bump -
Why do *YOU* prefer old gens?
Jerry DeMoss replied to Syonyk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The reasons I like the old gen stuff: I like the durability,simplicity,the way they look,I like that they are different,easy to get stuff for,but not something you see every day.I also like that the ea81 is really strong and easy to get parts for.I really can go on and on but you get the point. -
Hi, as the title says I would like to have anyone comment that has ran dual webers on their ea81.I am looking for info pertaining to jetting and fitment of the carbs.I have read earlier posts about people that have done it but I would like details.I would like to see a good starting point for jetting.Also I have read that some people have turned their webers sideways to accomadate the extra room needed for another carb.Anyone have pictures? Also needed is adapter plates if anyone has some used ones.Or even if you have another weber give me a shout. Thanks in advance for the info.
Nice project you got going Shawn.Thanks for letting me stand and watch the progress on the EJ22 swap and also for showing me around the shop.Was great to see the van.Thanks again.
Nice '77 wagon for sale in CO
Jerry DeMoss replied to zyewdall's topic in Historic Subaru Forum: 50's thru 70's
Most likely he is talking about the msd coil like: the blaster and blaster 2.I don't know that for sure though,but he also might be running the whole brain box type of system. -
Snow fun, and fubar'd rear something
Jerry DeMoss replied to MoscowSubaruDude's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Bent the trailing arm or the shock? -
Pugs are finally on, yay!!!!!! Watchout 56k
Jerry DeMoss replied to EYE_WHY's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Amazing how just changing that much can make your whole vehicle look totally different.Nice job. -
Sure,I will call you.Thanks.
Weber Carb Group Buy
Jerry DeMoss replied to bigjim5551212's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I am interested.Any chance you could get the jetting set correctly for dual webers?I want to run dual webs with my dually intake.Thanks. -
I have a solid lifter engine I tore down and wanted the internals. I am only going to keep the crank and the con rods.I want to get rid of the block and heads and cam.I also have the pistons which are in good shape.Anyway that is why I asked my question. BTW-When I was pulling the engine apart I read an earlier post by Shawn W about disassembly and it was very helpfull.I overlooked several times that one remaining bolt down inbetween the 2 cylinders on the right side of the engine.Very nice to know.Thanks
I would like to know if anyone can tell me if some of the internals of a hydro lifter block and solid are the same? The crank?Also are the connecting rods the same?I am assuming that they both are.I think the only differences in the internals is the block and the cam, pushrods and the rocker shafts.Am I correct in my assumption?Thank you all for the help.
That sounds like so much fun! That would be a real experience to remember.
Front Brake Question!!!
Jerry DeMoss replied to ejmartin's topic in Old Gen.: 80's GL/DL/XT/Loyales...
No I don't think you damaged anything.As long as the rubber seal around the caliper piston isn't cracked then there shouldn't be anything to worry about.Those calipers are pretty strong. -
Loud rear end...ADDED PHOTO
Jerry DeMoss replied to seattlelegacy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If you want to check your driveline get under there and grab it with both hands and rotate it back and forth while looking at the U-joint for slop.Good luck. -
Wheel bearings? -
Please save this brat from the crusher
I talked to Tom about it and he is just getting parts off of it to use on a cherry brat he got from NM.Pretty sure he has no intention of getting that thing liscensed. -
To up your compression ratio you can use EA71 pistons.Same bore just a little higher dome on the piston.You may have to get the pistons from a car in the junkyard. Use the search function and you will find alot of info on this.
I am anxious to see your project.Sounds really nice.Don't feel bad about forgetting gas.I once forgot to put on the coil wire and couldn't figure why I couldn't get the darn thing to fire.
