Everything posted by Jerry DeMoss
My XT is making a funny sound
Jerry DeMoss replied to cutie-ru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Might want to pop the valve cover on that side and have a look.But like Rick said it might be detonation.Try running some seafoam through it and see if it frees it up at all.You may have lifter starting to make noise.......Or your car just wants a peanut butter sandwich really bad. -
Where do I get pins for axles?
Jerry DeMoss replied to jupp24's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You could also check suby dealers or axle rebuild or supply stores. -
Just swap a n/a ej22 for the T when KBD isn't looking. Just kidding. I will keep my eyes peeled for good motors.
Look what the big brown truck droped off.
Jerry DeMoss replied to PeterD's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Look at the weber carb thread.I am sure that it will answer all of your questions concerned with jetting.Those carbs are very easy to rebuild.Good luck. -
Boeing uses Subaru engine in unmanned rotorcraft
Jerry DeMoss replied to swc7916's topic in Subaru Transplants
Thankyou for posting that interesting tidbit.I am very into the aviation world,being a certified A&P mechanic.I would love to see what this thing looks like.I wonder what engine it used since it was said it uses a 6cyl subaru engine? -
Cool Rick. Its just too bad you are having troubles with your ea81.There are plenty of ej22's to be had at the JY's.I hope we can find you a good low miler.Let me know what you decide.
Biggest wheels on subaru brat w/o lift..?
Jerry DeMoss replied to 81BRAT's topic in Historic Subaru Forum: 50's thru 70's
With the stock 13" steelies maybe just 185/70's but with pugs maybe a 205/65/14 or with the 15's. -
The Return of Mountain Grizzly...
Jerry DeMoss replied to mcbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I really like that wagon.I am sure it will be nice and purdy again.I know I had talked to you about your 87 brat and thinking about the toy axles on it,but if you change your mind let me know I would love to buy your brat. -
Looks really good with those tires.Nice pics.
ATTN CO BUMS! Left Hand canyon run SUN
Jerry DeMoss replied to kingbobdole's topic in Meet n' Greet. Your USMB Welcome Center
Sure ya do. Just a good chance to get muddy or dusty.And test the limits of the subes,and see who can go the longest without breaking something.Wish I wasn't sick when you guys went it would have been a blast.Nice pics BTW. -
Missing only on freeway, 4th gear? '84 ea81
Jerry DeMoss replied to lastchance's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That is a little strange to do it only in 4th.I think like the others said that it just wasn't warmed up enough. -
So I just got a weber.....
Jerry DeMoss replied to Jerry DeMoss's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If nothing else I will rebuild the carb and sell it to a vw nut who can use it or trade it towards a dgev.Or figure a way to use it myself. -
Thanks for the info.It kinda sucks that they are different.I did however forget to mention that it is converted to electric choke.I will have to check the carb out more.I already have it dis assembled and in the parts cleaning tank.I will have to check with redline.Thanks for the help. -
Poll time: Digi or Manual dash cluster
Jerry DeMoss replied to thesubeguy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I like the manual better also.Looks better I think and easier to fix if need be. -
I just picked up a weber 32/36 from a guy last night.It only cost me $50(couldn't pass it up) and came with a vw bug empi intake and air cleaner...Anyway it was covered in oil and couldn't tell what model it was till I got it home and cleaned it up.It turns out it is a DFAV.Just wanted to see what differences it has from a DGEV ect.Also wondered if anyone has a gasket kit/overhaul kit for one of these? I saw some on ebay but I thought I would ask first.Thanks for reading my post.
1978 Subaru Restoration
Jerry DeMoss replied to thewestsidegroup's topic in Historic Subaru Forum: 50's thru 70's
Nice to hear you are restoring an old brat.As for your decals you will need to talk to McBrat (the brat guru) he has very nice selection of them.Are you keeping everything stock as far as suspension and engine go?There are a few people on here that have ea71 engine parts.I am sure you will find what you need here.Also welcome to the board. -
I am starting to do this also to the various parts I am peicing together for a ea81 as well.Here is what I would do: 1. Port the heads(extensively on intake side) 2. Use the ea71 or ea82 pistons like said above 3. Shave the heads .020 to .040" thousanths 4. Dual carb intake or convert over to ea82 intake man. 5. Weber carb or carbs:) 6. Port intake manifold 7. Build a slightly larger diameter "y" pipe back to bigger exhaust
Welcome.What kind of car do you drive?
I am a fleet mechanic so I face this all the time.Use a heat gun.Usually the type to strip paint with.Heat from the inside if you can.(May have to take it off the car).Heat around the area itself so you dont concentrate heat in one spot too much as you could warp the plastic.Use something to apply pressure to it while you are heating it to pop it back into place.Hope this helps.
RHD brat would be cool
Yes,Brumby. Or Brumbisorus.
