WickedV6
About WickedV6
- Birthday 08/26/1968
Location
ELBURN, IL
Interests
Cars, Cars & more cars
Occupation
Accountsnt
Biography
Speed and car NUT
WickedV6's Achievements
Member (2/11)
10
Thanks guys, Ever since the shifter became harder to move (even prior to the long storage period) I had to play with the shifter/neutral safety switch to get it started. No, the solenoid does not engage, no clicking sound. I will jump the starter and see if it turns and take the shifter cable off and se if the Trans can be shifted by hand. The car was a 4wd but now only the fwd works, I don’t know if that affects any thing. Thanks again Prasad
I have a 95 Legacy wagon, I parked it my barn for about 8 months, and I drove it in there. Now I go to start, it doesn't want to start. The starter is not engaging. I took apart the shifter to check the neutral safety switch and I by passed it but no luck. The shifter seems very tight. I can only move it down only to drive nothing lower. Also nothing is really moving by the Trans when I move the shifter inside. Do I need a new shifter cable? Why wouldn't it start if I have the neutral safety switch by passed? Is there any thing in the tranny that is preventing it from starting? TIA Prasad
As always you guys were right on the money. I double checked the fuses. This time I checked with a multimeter. The fuse for the parking lights looked perfectly fine but when I checked for continuity, it showed it was open. It had a hair line break in it. Repalced the fuse and we are all good. Thanks again guys Prasad
Please help, I only have FWD, no power to the rear wheels. I don't know much about the history of this car other than; it's a 1995 Legacy, 214,000 miles, Automatic. I bought the car for next to nothing so I can't complain. I have to have 4wd due where I live and that was the sole reason I got back into another Subaru. I tried doing a search but there were only few posts and one or two about a fuse under the hood for 4wd but I think it was for earlier models but I am not sure. Where should I start? Thanks guys I really appreciate all the help here Prasad
