1 Lucky Texan
    105
  1. Crank pos sensor getting flakey? A VERY long time ago, I read of an STI owner that cleaned some debris (ferrous dust particles) from a CPS and it fixed some intermittent issues. Not sure why it wouldn't set a CEL...?
  2. Be aware, if it's like the 5spd on my 06 WRX, the shifter is held on the shift shaft by 2 spring pins...1 INSIDE the other!
  3. They replaced the slave. If they give me the old one, I might investigate rebuilding it and keep it with the other spares I have for the car. With fresh fluid and a bleed, maybe the master will be ok, if not, it's the onley thing left so, I might tackle it myself but really guys, maintenance and repair work is getting to be a challenge for me nowadays.
  4. slave cylinder I had the mechanic do it since it was in for its inspection sticker. pricey, intercooler had to come off. thanks everybody
  5. since it pumps back up, I figured it isn't a cracked lever. The problem seems more hydraulic in nature?
  6. Long time no write... After retirement, I rarely drive my wagon, after it sits for a while, I find the clutch pedal does not return after pressing. I CAN lift it and pump it enough to shift, then, after driving for a while, it starts behaving mostly normally. Anyone experience this? clutch master or slave cylinder????
  7. The only issue I've read about in the past is a CD getting stuck/not ejecting and it causing enough drain to kill the battery.
  8. seems unlikely at low miles, but a bad knock sensor can keep timing retarded and kill performance. Might be the only sensor that doesn't need to be OEM. most folks report $25 units work fine if you don't overtorque them and make sure to route the cable from them in the same orietation.
  9. that diesel is short enough? there were some Subaru diesel crate engines available at one time, or source a used one from overseas? back in the 70s, folks were putting Kubota diesels in some small cars....... or maybe a Mazda wankel ?
  10. you might try 'popping' the clutch pedal 2-3 times next time it fails. maybe the safety switch on it is failing. Or the one on the brake pedal?
  11. Denso or OEM (same?) is preferred for sensors. Folks sometimes report problems with aftermarket including Bosch.
  12. one very long shot - I once read of someone that had intermittent problems when turning, they found a wire harness section routed near the steering u-joint was abraded and shorting out.
  13. In the past, I've had spurious codes set, often with no driveability problems, on 2 different vehicles - that came down to weak/old/damaged batteries.
  14. I don't think so. The H6es get ECU control of the alt. best bet, find a local rebuilder and have your original alt. rebuilt. unless of course, it was already given up as a core. car may be down a few days. or check into parts from DB electric or Maniac motors(?) in Texas. even an alt from a wrecking yard (must be H6) is preferred over any alt from typical parts retailer .
  15. does the noise get increasingly aggressive-sounding with increased rpm, or, does it kinda come-and-go ? if the latter, might be a weak tensioner.
  16. our old 2003 had a an angle/elbow that leaked. Felt sticky and fragile? easy repair with some kinda vacuum line assortment kit from VatoZone w'ever.
