105
maybe inspect for cracked plastic or leaking hoses? when you say 'top-off', are you continuing to fill after the pump handle clicks off? that can lead to problems. Sure, rounding up to the nearest 10 cents or 'maybe' 25 cents is unlikely to be an issue, but the carbon canister can flood if you or another driver fills to overflowing every time - then particles of carbon can get into the evap system leading to issues too.
you want Dealer-supplied, or, Mitsuboshi belt dealer or NTN tensioner rollers to have Japanese bearings many threads on this , - online dealer parts house, local dealer (ask them to match on-line prices) ebay, rockauto, amazon, etc. do a search for threads about this. (IF you decide to change waterpump, get dealer or Aisin and metal gasket)
picking-up a car that needs the TB done (around 105K OR 105 months) can be a good strategy because, you can use the cost of that to negotiate a little lower price PLUS, you get the knowledge that the TB job is done properly by you or your mechanic. Getting a car with - say 120K miles from an owner that says "yeah, timing belt was replaced" might SEEM like a good plan, but some folks just do a belt-slap when the toothed roller (and other idlers, and tensioner) are likely points of failure.
start by finding a soob-friendly independent mechanic near you. ask in a new thread. 1. they may have a customer that is trading up/selling a car 2. They can help with a pre-purchase inspection if you find a car you like (does your sister live farther south? Superior Soobie near Portland is a great shop) the older a car is, the less important it's brand/model reputation is, and the more important it's prior care and present condition are. FB25 engines have a timing chain, no belt service to mess with. I think that starts with 2013 (maybe 12?) for the Outback 4 cyl.
see how 3 lines go to the carbon canister? remove one at a time before refueling, then see which one lets the car be 'normal'. that system has multiple modes of failure. My MIL's 2010 Forester had to have the tank dropped for stuck vent valve. as mentioned by wtdash , connecting the green test wire will cycle all those valves, at least put a finger or hose up to you ear on each one to make sure they cycle, if they do, then likely a clog or bad valve is the problem.
even though it could likely throw a coupla evap codes, try pulling various hoses off the carbon can. , refuel and drive. You may at least discover which system ,or, where in the system the problem is. If the canister has ever been flooded with fuel from top-offs, I'vread that carbon particles can travel to a valve and cause issues.
wel, if exhaust is severely blocked, a vacuum gauge will show you, check youtube and other on-line info on that. many folks have had bad/cracked knock sensors on older soobs that force the ECU to pull timing - kills power. if you own a smartphone, tou can use Torque Free app and an ELM327 BT or similar adapter and get data from the ECU. That might tell us about ignition timing and a:f ratio corrections. one idea, if you do a battery reset, pull neg term., press on the brake pedal, wait 10 minutes....w'ever , does the car run the same or better? if better, I'd suspect a sensor-related issue, if the same, might be more physical/mechanical. restting the ecu forces the use use of the 'factory rom map' and the car 'forgets and must re-learn adjustments from a:f and other sensors.
60 secs of heat is quite a bit. I 'accidentally' discovered what has been explained on the Forums once or twice by the 'gurus' - after warming the nut with the torch, THEN (carefully) spray with PB Blaster or 50/50 ATF-acetone mix. As it cools, it will draw the penetrant in. It was strut work that finally convinced me to buy an impact wrench. Wish I'd had it 35 years ago. I know it sounds crazy but, try some force in the TIGHTEN direction, maybe a little back-forth on it will bust the rust!
