105
^^^ what they said, tires should be IDENTICAL. run FWD fuse (see your owners manual about use of emergency spare tire) less desirable options; run new tire pair on opposite corners (only IF your rear diff is not limited slip), or, have new tires shaved down to match circumference of old tires (this may not work if the difference is as great as you say, plus, it wastes the utility of the new tires)
all 4 tires the same brand/model/size? any bucking/jeking/grabbing in sharp turns maneuvering in parking lots? will the car do tight circles on dry pavement at or 'just' above idle rpm? try swapping tire pairs front to back, inspect suff like lug nuts and brakes when you do this off course. you try the FWD fuse too.
maybe inspect for cracked plastic or leaking hoses? when you say 'top-off', are you continuing to fill after the pump handle clicks off? that can lead to problems. Sure, rounding up to the nearest 10 cents or 'maybe' 25 cents is unlikely to be an issue, but the carbon canister can flood if you or another driver fills to overflowing every time - then particles of carbon can get into the evap system leading to issues too.
you want Dealer-supplied, or, Mitsuboshi belt dealer or NTN tensioner rollers to have Japanese bearings many threads on this , - online dealer parts house, local dealer (ask them to match on-line prices) ebay, rockauto, amazon, etc. do a search for threads about this. (IF you decide to change waterpump, get dealer or Aisin and metal gasket)
picking-up a car that needs the TB done (around 105K OR 105 months) can be a good strategy because, you can use the cost of that to negotiate a little lower price PLUS, you get the knowledge that the TB job is done properly by you or your mechanic. Getting a car with - say 120K miles from an owner that says "yeah, timing belt was replaced" might SEEM like a good plan, but some folks just do a belt-slap when the toothed roller (and other idlers, and tensioner) are likely points of failure.
start by finding a soob-friendly independent mechanic near you. ask in a new thread. 1. they may have a customer that is trading up/selling a car 2. They can help with a pre-purchase inspection if you find a car you like (does your sister live farther south? Superior Soobie near Portland is a great shop) the older a car is, the less important it's brand/model reputation is, and the more important it's prior care and present condition are. FB25 engines have a timing chain, no belt service to mess with. I think that starts with 2013 (maybe 12?) for the Outback 4 cyl.
