105
lab analysis might help (blackstone , polaris ?) - metals or too much fuel, etc. in the oil would point to a bearing failing or weak rings allowing too much blow-by I guess.
- 43 replies
GD - bad engine temp sensor? - but I haven't read of pinging being a symptom.....?
- 43 replies
can't reacll if you mentioned the trans, but wonder if an input shaft bearing or , a cracked flexplate might do this?
- 43 replies
you have a PCV valve - on some years it's on the TB, other years it's on a head.
- 43 replies
kinda wondering if you could have a weak timing belt tensioner. It can mimic rod knock and I guess piston slap, but it can smooth out at higher rpms where rod knock gets worse (this is all, 'usually' of course) but that isn't really 'marbles in a can', it's like a rhythmic knock. I guess you've ruled-out loose heat shields? valve clatter? maybe an oil pressure test is needed? if it does it at idles, or off idle with a helper, could you pinpoint L, R or front rear of engine? maybe it is carboning-up quickly as GD said - he's a pro mechanic. maybe a PCV valve change would help with oil blow-by/control?
- 43 replies
doesn't sound like typical pinging to me. It should get worse with throttle demand as the ecu advances timing. if we could see the knock data/correction, that might be helpful. seems like you have plenty of experience though - just wonder what might sound like pinging at low load/rpm - is it a regular sound that tracks with rpm? is it a buzz/rattle or ????
- 43 replies
seems like higher octane should reduce pinging. maybe you could record the sound and post a link to it?
- 43 replies
plugs correct heat range for the car? does the pinging get better if you run high octane fuel?
- 43 replies
may need to scan the ecu for freezeframe data or better, live data. If you have a smartphone, an elm327 bluetooth adapter and an app can do that. I suppose slipped timing might lead to pinging so, confirm cam timing. was the old knock sensor cracked or decrepit in any way? what was the source for the present sensor?
- 43 replies
