1 Lucky Texan
    105
  1. are you experiencing a problem? post the symptoms and maybe someone will be able to offer a suggestion.
  2. car details? is the car new to you or did this problem just begin? any wrecks or work done on the car recently? many folks have good luck doing 1-2-3 drain/fills on the automatics. Delayed engagement can sometimes be helped a lot with fluid change and a bottle of Trans-X. and it's the only fluid you check while idling.
  3. .could be 2 different problems...on the noise going straight, sometimes there can be debris caught between back/inner side of the rotor and the brake shield. Could be a symptom of a wheel bearing going bad. Getting the car up on jacks and lifting/rocking each wheel in the up/down - 12 oclock to 6 oclock would be good. They shouldn't move. Listening to them with a mechanic's stethoscope while turning would be good to try too. checking the calipers for free sliding movement wold be a good idea. maybe they are binding. double check lug nuts - some recent posts about loose lugnuts or improper size lugnuts causing problems.
  4. is it in sync with wheel rotation? could someone pace the car on foot and pin down the location better?
  5. well, the wet clutch pack lives in the tail area of the trans. It swims in ATF. the front diff does have its own drain plug but fluid level filled and checked with the dipstick tube.
  6. check car-part.com or LKQ for a used trans. wonder if the car was abused in the past? different size tires or towed with 2 wheels down?
  7. my fear is, its the center diff. have read several posts and the MTs seem to always exhibit the symptom when warmed-up, but not stone cold. I don't really see how an axle would behave this way.
  8. ^^^ what they said none of them come stock with power if the key is off however. some folks modify them for all-time power. try to buy a quality adapter - I have read of cheap ones that wiggle too much or w'ever and short out and blow the little 'fusistor' on the back of the power port. nuisance to hazard issue.
  9. if she is near RetroRoo in Henderson, our own site-owner could take a look, or, contact user @traildogck over at http://www.subaruoutback.org/forums/67-classifieds/330529-diy-facility-classes-denver.html he has a mobile repair biz in Colorado, he'd be able to investigate for any problem and likely spend some time to make sure your daughter knows enough about wheels to at least get one on safely enough to take to a shop for final torqueing. If she has a Discount Tire in near her city, they have a superb reputation for customer service, they've helped my wife. MIL and all 3 daughters several times with free flat repairs and new tires and other issues. Might be best to schedule a time on a tues, wed or thurs as they can be very busy on/near weekends.
  10. the original problem may have been due to vandalism or poor practice at a tire shop - the present problem 'could' be from the emergency purchase of lugnuts and those are now part of the problem. being remote from her, I think you will need to send her to a shop and have them THOROUGHLY examine everything on the car. And, a typical woman may have to tighten and loosen lugnuts with half their body weight pressing down on a typical jack-tool wrench. It's tricky. Add to that using a 'star' pattern and not tightening in a circle, and it's easy for some folks to get a wheel 'on' but it be improperly torqued-down. And that is with new/known good parts.
  11. If vandalism is suspect, there are aftermarket security lugnut sets available (with a keyed or spline nut requiring a special tool). No, they don't guarantee the nuts can't be removed by a determined thief/knucklehead - just presents a deterrent that may send them to their next , easier, target. she could discuss those at a retailer like Discount Tire or maybe NTB as well.
  12. yeah, may not be torque bind as you keep saying popping. Torque bind would cause a binding feeling in tight circles/turns. It may cause a sound as well. could you get the car to do this in a parking lot at slow speeds? if so, have someone pace the car and listen for it to be central, or louder on one side than the other. aftermarket new or rebuilt axles are 'iffy' ,aftermarket rebuilt the worst.
  13. if the car has replacement...; lug studs, lug nuts or wheels - there's the possibility the nuts are 'bottoming out' before proper clamping force is achieved. I'd consider having her stop by a Discount Tire and have them inspect everything.
  14. when warmed-up, will the car buck/jerk in tight circles on dry pavement? OK turning sharp when stone cold, popping or binding/jerking in sharp turns when warmed-up is 99% gonna be the transmission's center differential. mismatched tires, very odd carrier bearing, wheel bearing or u-joint failure should be ruled-out but, sounds like the trans.
  15. a month or so might also be time for a poorly tightened wire to vibrate loose...double check alt and battery connections.
  16. video not seen look inside the reservoir for bubbles - you may have air being sucked-in. very common problem
  17. could be knock sensor - cheap/easy to swap sometimes a failing cat conv will clog the exhaust
  18. any chance of wiring damage from rodents or pinched by some work that was done?
