105
coupla things to try, when you feel it will fail, or immediately after a failure - hold the gas pedal to the floor while starting. Don't pump it or lift until after it starts. that is the 'clear flood' condition for the ECU. if you think it's fuel startved, try spraying some starter fluid in the intake. also, some older soobs have had crank position sensors fail when hot.
any oil on the plug wire boots? any differences in the weather conditions when it starts vs when it doesn't ? have you tried starting it with etherstart/starting fluid? could it be flooded now? are the plugs wet with fuel? (if so, hold the gas pedal to the floor and crank , that's the ECU's 'clear flood' procedure) is the IACV hose disconnected from under the intake tubing?
many parts stores can test alternators/charging circuits. consider a used Subaru alternator from a junkyard - many rebuilts have a poor reputation. Or, locate a local rebuilder and have yours rebuilt.
- 4 replies
- Alternater
- electrical
(and 2 more)
Tagged with:
it's cool, I could have waited longer before posting but his original post went several hours with no response at all, not common here. likely not agressive enough for regular off/soft road use, but the Pirelli Cinturato P7s on our OBW are great - helped get us home from CoSpgs in winter storm 'Ursa' , we were the pilot car leading almost a dozen others off a closed road between Capulin and Clayton NM. hope others reply
what do you feel? seat-of-pants vibration? steering wheel? brake pedal? any sound? are the pads wearing evenly - side to side and inner vs outer? same thickness and parallel? swap tire pairs front to back? I think I'd also check rear bushing on the lca - just not sure where else to look. maybe others will have an idea.
miles on car? check inner tie rods for play. it's extremely rare for rotors to actually 'potato chip'/warp. Vibration or pulsing when braking is much more likely due to uneven pad deposits. This can occur under a couple of conditions; 1. slamming to a stop on hot brakes and holding them clamped at a long light or waiting for a train. etc. 2. Some folks will develop uneven deposits from weeks and weeks of very light brake use. Like lots of highway driving and very little and/or smooth 'drama-free' secondary road drive. one other uncommon thing is a car that sits in certain weather conditions unused for weeks/months at a time. Often, an easy fix if, find a LONG stop-free road and maintain 30-40mph while using your left foot to 'drag' the brakes. Enough to feel it. Do that for a coupla blocks - making SURE you can follow-up with a stop free half to 1 mile cool-down run. If the problem gets WORSE, you may have a bad spot (altered temper to the alloy) on a rotor. If it gets better, you may need to repeat the left foot drag, or investigate a more intense "bedding in" procedure. good reading here; http://stoptech.com/technical-support/technical-white-papers/-warped-brake-disc-and-other-myths
