				Posts10142
				Days Won105
	I did mine because one side had a crack about 40% of the way around the rubber, HOWEVER, both of them had very rough/crunchy feeling bearings. under 70K miles on my car (but almost all surface streets) nothing wrong with leaving them in if the bearings feel OK - but check them - easy enough to pull and swap during the procedure.
	front struts for my WRX a few weeks ago - $67 each. group N mounts were more than 'stock' but, maybe $220 total? Outback stuff might not be much different? struts from Amazon, mounts from ebay - rented strut spring compressor from VatoZone - $Zero I'm slow at car work - still, only took about half a Saturday. and aftermarket KYB for soobs are 15% stiffer than NEW OEM - so, if you avoid jy struts, car will feel MUCH more 'planted'.
	you can search but, axles are a HUGE problem for people, the further you deviate from OEM/new, the more questionable/risky. worst is typical parts store rebuilds. new aftermarket is a coin toss (at present, good luck from new FEQ brand on my WRX) MANY people do great with used OEM from junkyards - might be a good idea to reboot the inner joint - about $20 r so and some time.
	most common issue as mentioned above, loose due to low torque when replaced after TB system service. known but less common is as said above also, it's a 2-piece pulley and the rubber between sections can degrade. either way, it should be addressed. new OEM are kinda pricey, consider a Perrin aftermarket lightweight pulley if yours is bad.
	here, the a/c system leaks respond well to replacement of 2 o-rings at the compressor - easy. Some folks replace those 2, and the Schrader valves. Charge with the volume listed on the label underhood. I have had to do this too both my 03 and my 06 - holding charge well now. You CAN of course , make the repairs,evacuate (I rented a vac pump from a parts store) to both check for leaks and remove moisture, then charge. You can also charge with one can of refrigerant with a UV dye so future leaking is easier to locate. read here; http://www.subaruoutback.org/forums/99-do-yourself-illustrated-guides/43428-diy-c-air-conditioning-leak-refrigerant-repair-5-less-15-minutes-less.html?highlight=diy+a%2Fc+valve+o-ring hopefully someone with more experience will respond and address your other question as well.
	25 year-old thermostat might be getting sticky radiator might be partially clogged....who knows without testing/examination? start with the easy/cheap stuff and work your way up no streams of bubbles is a GOOD sign but, don't drive it when it's overheating - that's a recipe for destroying headgaskets for sure as a test, you can also run with the t'stat removed
