1 Lucky Texan
    105
  1. kinda reminds me of all the dieseling and knock cars did in the late 70s and 80s - they told us it was "the sound of economy" lol! they brag about a 5% increase in FUEL economy but they're ashamed to tell folks they're gonna burn oil 300% faster than before!, the LEAST they could have done is WARN people that they must check their oil more frequently. And why doesn't the maintenance schedule have a 1,000 mile interval with an 'I' to inspect the oil level? still, if this is the new normal, some of us old guys will struggle to adapt!
  2. are plugs wet? maybe flooded - but that seems unlikely to have caused the original stall-out.
  3. it isn't too difficult to inspect the fuel pump, just be careful with the plastic bits on top. see; http://www.subaruoutback.org/forums/110-gen-2-2000-2004/41182-symptoms-fuel-pump-o-ring-problem.html
  4. interesting I thought the OEM trans filter was internally built differently from an oil filter? First I heard of anyone using an oil filter there.
  5. I have more trouble with the auto stick but, general consesnus is to wait longer, and use the lower reading on the 2 sides of the stick. As my eyes have gotten older, I sometimes need a lot more light if the oil is fresh.
  6. well, it points to the system losing pressure when hot, not sure WHERE it would be happening....you'd expect if it were a line/hose under the hood, you just might track it down by smell. but, I suppose it could be an injector or the pump....?
  7. interesting, I don't think they both are controlled by a single relay that could be stuck. maybe the CTS is bad telling the ECU the car is always hot?
  8. heartless, thanx for the post - I also have been lubing it unsuccessfully, I never thought about cleaning it first, makes sense though.
  9. next time you feel certain it would fail to start properly, cycle the key to ON (not start), wait 3-4 seconds, back to OFF, to ON, wait, back to OFF, to ON, wait 3-4secs. back to OFF, then immediately try starting. Each ON cycle should fire-up the fuel pump to pressurize the system. if, as I also suspect, Subaru Scott is right, the newly pressurized system should start properly, proving that, over time, the hot/warm system is leaking-down fuel pressure.
  10. put a hose to your ear and carefully move it around in the engine bay to locate the area it's coming from? check for a crack at the Y pipe on the exhaust. try a vacuum gauge test - get it on loan from a parts store, check on-line for guides of all the stuff it can show.
  11. I always wondered how much debris was in a trans pan - re they usually nasty? (it's been decades since I pulled a trans pan, on US cars, and they didn't 'seem' bad.)
  12. the smell could be grease from a torn CV boot. being on a low traction service is the least likely to create torque bind. Of course, it doesn't mean the car didn't arrive to the gravel area with a problem.
  13. if you feel it in the steering wheel, you want to have lug nuts and studs checked for proper torque and cracks, etc. as said above, swap the tires front to back and test. sometimes, flakes of rust or other debris can be caiught somewhere in the hub-rotor-wheel 'sandwich' and cause issues.
  14. my youngest daughter has back pain and when we were replacing her car, the most economical vehicle we investigated that had back-friendly seating was a Chevy Impala. have you ever tried back support product like those made by Obus Forme' ? it seems to help many folks.
  15. My brother-in-law's Toyota seized its engine during an oil consumption test! dealership didn't believe him when he complained of excessive consumption. He was a staunch multiple Toyota owner - now driving a Honda.
  16. tune-up as said, NGK plugs, new NGK wires (if original, yours are 21 years old) , check for oil on the plug boots. if oily, may need valve cover gaskets and plug tube seals.
  17. ran across a mention that the low-tension coated piston rings was Toyota technology. thanx Toyota!
  18. gd is definitely the expert here, but from reading, it seems to me, rod knock always is progressively worse with increase rpms. Tensioner noise may smooth-out, then might come back in at a different rpm 'range', then smooth-out again. to me, you have tensioner noise. the more recent noise might be caused by water in the spark plug tubes???? If the car is new to you, I'd do a full and 'proper' timing system service - not 'just' the tensioner. I suppose slapping a tensioner on first though, as a diagnostic test, could tell you if you want to procede. GD - does that engine have a 7mm oil pump? anyway, at those miles, I'd consider getting an engine from a wreck with maybe half the miles, put MLS headgaskets on, a timing system service, maybe a 10mm oil pump and swap engines.
  19. there's no other term that describes it? hissing seems like it could only be caused by a gas, air or exhaust wondering if a caliper could be dragging, clutch slipping or....?????
  20. double check the 'bottom' of the air filter box - both my cars have broken slots wher e those tabs go. (right now, I have zip ties holding the box halves together) Even before they were broken, easy to misalign the box after a filter change. vacuum gauge testing might be a good idea.
