no fuel no pumping
1 Lucky Texan replied to damnsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX^^^ yeah take care of YOUR pump first!
2005 Impreza ADW issue
were any tires changed recently?
1998 Forester, engine knocking.
1 Lucky Texan replied to My64bit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXran across a mention that the low-tension coated piston rings was Toyota technology. thanx Toyota!
1 Lucky Texan replied to My64bit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgd is definitely the expert here, but from reading, it seems to me, rod knock always is progressively worse with increase rpms. Tensioner noise may smooth-out, then might come back in at a different rpm 'range', then smooth-out again. to me, you have tensioner noise. the more recent noise might be caused by water in the spark plug tubes???? If the car is new to you, I'd do a full and 'proper' timing system service - not 'just' the tensioner. I suppose slapping a tensioner on first though, as a diagnostic test, could tell you if you want to procede. GD - does that engine have a 7mm oil pump? anyway, at those miles, I'd consider getting an engine from a wreck with maybe half the miles, put MLS headgaskets on, a timing system service, maybe a 10mm oil pump and swap engines.
2000 impreza rs Hissing sometimes at medium to full throttle, loss of power during this.
1 Lucky Texan replied to Subardoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthere's no other term that describes it? hissing seems like it could only be caused by a gas, air or exhaust wondering if a caliper could be dragging, clutch slipping or....?????
Windshield
1 Lucky Texan replied to wim's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXis it a crack? chips can be repaired.
1 Lucky Texan replied to Subardoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdouble check the 'bottom' of the air filter box - both my cars have broken slots wher e those tabs go. (right now, I have zip ties holding the box halves together) Even before they were broken, easy to misalign the box after a filter change. vacuum gauge testing might be a good idea.
2003 Impreza Outback Sport CV axle
1 Lucky Texan replied to Imandykk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhow long did the OEM axles last? maybe get some used rear axles, regrease and reboot, and run them until they need replacement? Heri makes an axle with extra articulation - you might check into those.
BRZ, WRX or Impreza?
1 Lucky Texan replied to Vela's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat have you been driving? what did you like about it? what do you want in the next car that you didn't have? without more info, my knee-jerk reactions to your post are one of 2 responses; 1. which one did you like during the test drives? 2. get the Impreza.
98 Legacy Outback refuses to run after O2 sensor
holding the gas pedal to the floor while cranking is the 'clear flood' mode.
Strange A/C issue
1 Lucky Texan replied to Arty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXalso look at any 1157-type bulb. turn signal/marker/brake combo or w'ever. The dual filaments occasionally 'sag' and odd things can happen when marker lights or turn signals are on. also look in the bottom of each bulb's socket for corrosion. also, longshot but, test for a change in the problems with the tailgate up - maybe wiring problem inside the 'boot' from the body to the hatch.
Strange A/C issue
1 Lucky Texan replied to Arty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbattery cables. Sometime they seem OK externally, but corrosion can 'wick' under the insulation.
When put in park theres a loud clunck from tranny
1 Lucky Texan replied to holly579's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX^^^^ and, when they say it's normal, be prepared to point to another one and have them demonstrate it.
2001 forester s security light blinks 24/7
seems normal? you might check the manual about Valet mode - but I think that's a different blink pattern ???
Cracked Gas Tank Vent Valves
1 Lucky Texan replied to TexasOpa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXis the check engine light on? have the code(s) read at a parts store and post them here. does the car start and run OK? if not, what symptoms do you have? what year and miles? new to you? well maintained or unknown history on car?
2017 Legacy dash large center Vent or Speaker?
1 Lucky Texan replied to holly579's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdefroster ?
power steering hose connections.
1 Lucky Texan replied to matt167's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnvr md, read post wrong
Timing Belt installed Gears lined up
1 Lucky Texan replied to 06SubLegTx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif you want a triple check before firing it up, find the tooth count for your engine. With the marks lined up as you are showing, count the teeth between the marks. that's what I did on my wrx after pulling the tensioner pin, cranking-thru twice, but before starting.
08 Impreza, terrifying noise.
1 Lucky Texan replied to Wildem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXo-ring on the hose adapter on top (well, on top of my 03 and 06 soobs) goes bad a lot. common problem that lets air in. I have read of bad hoses and hose clamps causing air entrainment as well.
Flashing lights, sputtering and more
1 Lucky Texan replied to lassensurf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhow many miles on this beast? how old are the plugs? not unusual to get a couple more disabled functions anytime the CEL is on - standard nowadays to disable cruise and traction and maybe some other features. get the misfire under control and go from there.
New to me '98 Impreza Outback Sport
1 Lucky Texan replied to FlyB0y's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are folks that warn against using full travel if using the pedal to bleed brakes on older vehicles. It's evidently possible for some corrosion in the MC to cut into a seal or o-ring. It doesn't seem common in practice, but has been mentioned. if the pedal drops, that's different than feeling 'mushy' so, make sure you're chasing the correct problem. I only know about adjusting p-brakes on some rear disc cars. You may have some adjustment under the console but, that is probably meant to take up slack in stretched cable.
Rear strut replacement - tips - especially on coil compression
1 Lucky Texan replied to milty60's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXrear springs are much easier than fronts. sometimes, you get better clearance for a socket if one compressor's hex-head faces the opposite direction from the other. doing struts is why I bought my corded electric impact wrench from Lowes - should have bought one 35 years ago!
1 Lucky Texan replied to FlyB0y's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdid you keep the MC topped-up? are you sure? if it sucks in air - may have to be 'bench bled' . but, it isn't unusual for folks new to Subaru to complain about the brakes feeling soft. On a vey old car, the caliper hoses might 'balloon' and replacing could help. Other folks claim a master cylinder brace helps.
Early USDM WRX 5-speed Issues
1 Lucky Texan replied to ayykimber's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX^^^ now I think of it, I had the EXtra-S, flelt notchy/scrape-y in the summer. guess they have something different now - HPGO ? probably worth a look. the tech that did my rebuild felt everything, including the synchros looked fine. said it's just 'bad luck' .....? I dunno what to think, but, this is likely my last manual - I just love the car, can't really afford another 5spd disaster....but, I guess it either happens or not..... stupid glass transmission......
1 Lucky Texan replied to ayykimber's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmy 06's 5spd ate 2nd gear. I was told the case flexes too much and 3rd or sometimes 2nd gets destroyed. one of the reasons I waited so long to get it back from the shop was, there was ,evidently, some part that must be specified at a point during assembly (a shim? washer?...?) that was sent that was the wrong size. maybe whoever rebuilt your trans didn't get a good measurement on that shim? many people report clashing with full synthetic gear lube. NON-synth GL-5 seems the best. There is a walmart synth blend that is cheap and has had some good reviews. At present I have Amsoil Severe Gear in the trans - dunno what it will be like for a full year, but it is a little notchy, but less than the Subaru oil. Best I've had in there was Redline Lightweight Shockproof. Motul has a lot of support, maybe I'll try that in the future. but, really leaning back to the Redline. Temps in Texas may mean our 'best' fluid wouldn't work well in a Kansas winter though! have you pulled your drain plug? maybe the magnet will show you something? (but, it sits next to the diff and some bulkheads/webbing in the trans probably keeps 'chunks' of gear teeth from getting to it) GD is the expert here, just relating my 5spd horror story - $2100 for a rebuild. under 70K miles, no power mods.
