1 Lucky Texan
    105
  1. possible dragging brake pad, possible debris between rotor and shield... bearing still quite likely.
  2. I would say 'quite likely' . But, personally, I'd have enough doubt to try a quality rad cap and a soob-style t'stat (there ARE aftermarkets with the larger capsule so, depends on what you actually installed) before condemning a 2.2 often, when the car is overheating from a bad HG, there will be visible bubbles in the rad or overflow. if it was an early 2.5, yeah HGs. there are other guys here though that could guide you better I think.
  3. personal preference, the autos are JATCO but have front diffs and rear wet clutch packs added. If well cared for they are robust. seems to me, soobs that have been thru several owners are more likely to have had one their 2-3 oddball features screwed-up by some owner that didn't care for them well. They must have matching tires, they must have a thermostat with a large wax capsule, it's seems easy for folks to drain and fill the wrong fluids at times, etc. If they have ever overheated or been operated with mismatched tires - their lifespan can be compromised. buying a one owner from an individual can work out well. Or, if you want a project, making a good one from a coupla wrecks/part-outs might get you a nice ride. you might check the classifieds here and over at subaruoutback.org
  4. did it overheat when she was at a light, waiting for a train, or parked idling? fan could be intermittent have you checked the coolant level in the radiaotor? is coolant being pushed into the overflow? do you KNOW the car has a Subaru style thermostat?
  5. cars101.com may have some info for you. while not common, a Baja might be a good choice for you. looks like you're near Horne Subaru so, there may be some vehicles there to test drive - or head into Phoenix?
  6. not sure about 98, but there are 1 or 2 'transition' years where there is easy confusion on which brake equipment fits.
  7. can you remove shafts on the SVX? also, that car is likely gonna need struts and springs all around
  8. if the Forester is like our Outback, you'd go under the rear seat. Pump and it's float is on the right side (US pass.) and the second float is on the left. You can probably find images and youtube videos , if not for thr Forester specifically, for some similar soob model to get an idea of what to watch for, searching for a schematic would be a good place to start - if the problem is an abraded or rodent-chewed wire somewhere, that means you wouldn't need to pull the access off the gas tank. and be careful about fumes. - it wasn't bad when I inspected my fuel pump (for a different reason), just something to be aware of. on the smell, most likely thing, Impreza-based models of that vintage have fuel clamps in the engine compartment that leak in the winter - many people have solved the leakage by just tightening them. Other possibility would be a rusted filler neck or evap system problem - but those usually throw a code. when it indicates empty - is it really empty?
  9. 2-3 things; any other electrical problems or new alternator recently? could be a ground somewhere is intermittent. there are floats on both side of the tank, one of them seems to be sticking (most likely) I suppose there could be an issue with the jet pump - but this would only be true if, when it measures empty, it only takes 6 gallons or so, instead or 12 or w'ever (this seems least likely problem)
  10. it is over-filled with refrigerant and the H tube or orifice w'ever can make a hooting noise like that. read of it 2-3 times.
  11. you might check for slipped timing, 1 tooth off? what's the general condition of the car? well maintained? new to you? when was the timing belt system last serviced?
  12. be sure to ask over at subaruoutback.org as well. I can't answer the question directly, but it would help folks if they knew your intended purpose/goal and how much lift. etc.
  13. they will cycle the fans, various relays, for the evap system, etc..... as a test. I've never used them yet, but most Subarus have them, not sure about the 'modern' ones . They are small, green connectors tucked away under the dash somewhere - I think I have read of them sometimes secured to the steering column with tape?
  14. yeah, go ahead and post the machine shop and if you had a good experience with them. Aside from me, maybe needing them someday, others may read this thread in the future looking for help here in DFW.
  15. it's a frustrating issue for all of us. IMHO; after new, 'best' is probably a regreased/rebooted used soob axle from a junkyard. next and variable in quality is new aftermarket (FEQ, Raxles, Suretrak, EMPI, etc.) most everyone agrees that the most unreliable are typical parts store rebuilds.
