105
I wish,... that's what I was asking you about. I had to have 2nd gear/rebuild fixed in my WRX's trans - AWD Tuning in Flower Mound did it. But it's quite far from where I live. I think they were VERY fair with the price, just kinda slow getting it done. Everything else I've done myself so far but, I really can't get deep into it and my age, lack of experience and lack of a 'helper', makes it more difficult to do 'heavy' wrenching. I recently had an air bag recall done (cost me $0 and I got a loaner) on the Outback at the new Sam Pack dealership in Grapevine - but their labor rate is $135/hr !!! It's an option but, pricey and still a longer drive than ideal. Dunno what I'm gonna do when I need a clutch. I might try MP Auto in Pantego - they've helped my daughter a lot and have good reviews - but I dunno how Subaru-experienced they are. I guess a clutch change shouldn't be tricky for them. If I needed an auto machine shop, guess I'd call Arlington Automotive Machine first and have a conversation, I just haven't needed that, yet.
- 33 replies
swap axles side to side, maybe it will help find a bad axle or prove the diff is the problem? otherwise - what he said, you might find a lower miles trans from a wreck - chances are decent it was running well when the wreck happened. Fresh fluid and maybe a bottle of Trans-X. reject any trans with a dent in the pan - be very careful with any torque converter that slips out of place - google it, must be seated properly.
- 32 replies
what shop? yeah, the rear main seal 'almost' never leaks - I think in years of reading across several subaru forums, I read of ONE leaking, and it may have been previously replaced. Inspecting the air-oil cover is a good idea, though,the problematic ones were the old plastic covers. gd - are there spots on the crossover pipe he should look at? basically, where would you want to get your eyes to check o-rings/seals and for rust, etc.? what are the 'gotchas' to be careful about over or under torqueing?
- 33 replies
Might have time for an off-road drive this time in C'Springs . But, I have no mods and will be on all-seasons. Just wondering if there's anything for flatlanders that might get them a little more rugged scenery , without needing a winch or a shovel or a buddy with recovery straps. Not that I, personally, wouldn't love an adventure - but the wife would like to keep her car greasy side down - and we need it to drive back to Tejas.
wow - what dealership/shop was that ? you may be making this a bigger project that needed. nothing wrong with that if you want a project. front crank and cam seals are often, not always, changed at timing belt service. If they look dry, you could wait on that. never read of rear seal change as a PM - and although I understand on the oil pickup, I dunno if it's worth doing if you aren't into the pan for other reasons. Let us know how that goes. Kinda want a Killer B on my WRX, but, I'm afraid I would introduce a leak from the pan as I have no experience with modern sealant use. if you pull the heads, it's my understanding the bolts are re-used. But, new cam cover gaskets would be a great idea. kinda out of my element so, maybe gd or others can advise you better.
- 33 replies
gd is telling you you can buy a new mount for the tensioner - no hassle and no helicoil. gd - isn't there even a design change on the mount - if I recall correctly, it's an upgrade. (or maybe that's only on turbo engines, something about the steel insert the hydraulic pin rides against?) anyway - it's number 9 is this diagram (part # 13156AA052 I THINK, confirm before purchase)
- 33 replies
GD - could he do leak down tests as-is? anyway, if the engine was running when a car was rear-ended, it should be OK. But, rebuilding one or both of your heads is probably cheaper than an engine purchase and swap....dunno.
- 33 replies
well, other things under a car can make noises, but if the original diagnosis was correct then, the part you received seems to be bad. (slim possibility but, maybe the shop didn't tighten the axle nut well or, they left an endlink loose or.... some other re-assembly issue is now the problem?) was it a rebuilt axle? they are often reground to receive larger ball bearings, the grinding 'should' be done by a multi-axis machine, not by hand. and, it should NOT remove all the case hardening. and they should use good lubricants. and they should pay attention to 'clocking' the joints (installing them correctly in relation to each other's rotational position). if you are using your own labor, the 'lifetime warranty' that comes with them isn't quite so bad - makes them a tempting risk. But, you might now have to pay labor charges again. Many people have been down this road.
the main complaint I read about the blends is, you don't know if they are 50% synth, or 1% . maybe you could discover over at www.bobistheoilguy.com . LOTS of info and discussions about oil over there.
- 18 replies
give AWD Tuning in Flower Mound - a call, but, not many places around I'm afraid.
- 4 replies
- 1990 Legacy
- mechanic
(and 1 more)
Tagged with:
