105
the main complaint I read about the blends is, you don't know if they are 50% synth, or 1% . maybe you could discover over at www.bobistheoilguy.com . LOTS of info and discussions about oil over there.
- 18 replies
give AWD Tuning in Flower Mound - a call, but, not many places around I'm afraid.
- 4 replies
- 1990 Legacy
- mechanic
(and 1 more)
Tagged with:
Living and working in Arlington for a while now - raised in Handley (east Ft.W)
- 18 replies
the schedule in the OM has a time side as well. The TB system is 105K miles or 105 months, w'ever is first. The toothed idler is often the weak spot, sometimes the tensioner of another idler. The grease goes bad and they seize or loose their bearings. Very rare it seems for the belt to break, unless caused by the chaos from a seized idler.
- 18 replies
first 2-3 stops should be in a 'controlled' area in case there's a lot of rust the pads need to get through. I guess monitor for any issues after you begin driving it (sticking calipers, rodent-chewed wires, etc.), perhaps accelerate some fluid changes. Tires over 6-7 years old or more might be starting to rot ?
way overdue for TB systems service if it hasn't been done.
- 18 replies
there's a Forester forum - try over there. maybe also at nasioc.com ?
- 5 replies
- Forester
- Auto to manual
(and 2 more)
Tagged with:
maybe 9 years or 105K miles for timing belt system service, but headgaskets?
- 18 replies
if you hear the click, then it isn't the neutral safety/clutch switch. most likely, the solenoid contacts and possibly plunger need replacing on the starter. kits can be had from ebay, amazon, elsewhere and there are likely youtube videos demonstrating the repair. best test for the solenoid - next time the car exhibits the symptom, whack the starter with a piece of wood. light-moderate tap, try to start, repeat a coupla times, maybe ad some 'oomph' and try a coupla more times. Don't use a hammer or herculean force.
just replace the bad one. 750? how much is a new axle from a Subaru dealership! if you cannot do - or have a mechanic do for you - the grossgary suggested reboot of a used axle. I think, if I were in your position I would roll the dice on an FEQ, or EMPI or SureTrak axle from Amazon or RockAuto . Based on a conversation with a local builder/tuner, I'd probably get FEQ. I've had one on my WRX for a while, seems OK. Check Amazon? just a thought.
