105
did you ask or position yourself to watch? NEVER do that - they may suspect you are a 'plant' from the State to find 'cheaters'. They must do everything. I know someone who lost his license because a lug nut was missing - behind the hubcap. Another tech I know lost his inspection biz because a vet begged him to let the illegal window tint slide thru. Yeah, he was a vet too. Total set-up. I try to go where I went last and sit with my back to the car.
thanx, I was googling a little and saw where there's a lot of dust and chunks inside some of those Mitsuba. are they 2 or 4 brush? is there an upgraded brush plate or brushes? and thanx for letting folks know about this.
- 18 replies
- starting
- long crank
(and 2 more)
Tagged with:
^^^ interesting. Other than visual inspection, is there a test for that? does whacking the starter alter the brush's contact or ????
- 18 replies
- starting
- long crank
(and 2 more)
Tagged with:
yep - I can 'troubleshoot by the law of averages' for a lot cheaper.
- 18 replies
- starting
- long crank
(and 2 more)
Tagged with:
if original, battery may be getting old. It can be tested.
- 18 replies
- starting
- long crank
(and 2 more)
Tagged with:
next time if fails, try 2 things but not at the same time. whack the starter with piece of 2x4. jam it on or knock it - depending on the room you have. Try that several times and try starting. If it starts after whack - bad contacts in the solenoid. wiggle the battery cables. they sometimes can have corrosion wicked down under the insulation - compromising their conductivity. or the bad terminals or bad gnd connection.
if you start it and simultaneously have someone begin spraying starter fluid in the intake - will it continue to run? if so, fueling issue, if not, ignition/electrical or air. I'm no expert and certainly your project is beyond my abilities but, one easy thing that can happen on many cars that fail to start after some repair work is disturbing the idle air hose or issues with the IACV.
^^^^point taken The discharge hose on our 03 H6 has been changed twice. Kinda wonder about vibration since it bends ~90* from the comp. to the condenser. . maybe that 'elbow' of rubber flopping up-down causes early failure? I have looked for a way to brace it - doesn't seem like I could come up with a 'clean'/elegant way to do it.
if incompatible lube was ever used in the past, the rubber bushings on the pins can swell and cause problems. Some folks just remove them. They only block a little a dust and maybe reduce a little rattle occasionally. http://www.subaruoutback.org/forums/66-problems-maintenance/35423-caliper-slide-pin-missing-rubber-sleeve.html
