105
most wrecks were driving well when they crashed so, a used trans is not an uncommon repair. There's risk and/or money in some uncomfortable ratio no matter how you proceed. If you really want to save the car for a while, maybe a well-known transmission shop (or even a dealer!) willing to warranty the entire trans for a significant period is a way to proceed.
has the timing belt system ever been serviced on the car?(shoulda been done around 2010 or 25K miles ago) if not - you've got that expense. if you want to do more troubleshooting, axles can be swapped side-to-side. maybe the symptom will follow or change. are there any pieces of metal on the front diff's magnet - or just a small amount of sludge? have you searched car-part.com or LKQ for a used transmission? Everyone fights the axle issue - most often, used Subaru axles rebuilt with new grease and boots are still better than new or rebuilt aftermarket. If your axles are aftermarket, there's a 100X greater chance of them being bad. If they are original but the boots have been torn for a long time - of course it's possible for them to be bad, but best replacement is still used OEM axles than have been regreased/booted.
couple of ideas - find the tooth count for the engine - line up all the timing marks and count the teeth between marks. (the lines on the belt won't line-up again for 200-300 rotations, it's crazy) double check the tube from the IACV to the in take tubing hasn't come off. recheck any ground wires or connectors that may be loose.
- 4 replies
- 1
- 2.5L
- timing belt
(and 2 more)
Tagged with:
if you're just within a coupla inches with your jack - you could jack to max - set your jack stands, then add a block of wood to the jack pad and lift a little higher. I wouldn't recommend getting crazy with this, but it might help if you're 'close'. letting air out of the tire might help a little as well.
I guess I 'really' can't tell either - I try to ask here, stay with OEM or 'name brands' or , at RA get something with the 'heart' symbol - or read reviews if buying from Amazon. but some of the above just comes from word-of-mouth when I was younger, and reading on the Forums nowadays. if it's a 'consumable' item like brake pads or fan belts - I stay away from the 'economy' items. Been burned in the past on those.
(how does the trans shift with the synthetic gear oil? many people report problems with clashing unless running conventional GL-5) www.bobistheoilguy.com may be an interesting place to find some info on your question. There have been anecdotal reports in the past of use of synthetic oil in engines previously lubricated with conventional oil developing leaks. But, if modern synthetic formulations include any additives designed to help gaskets/seals be more pliable or expand, that leads to the possibility of reduced leakage. or perhaps after the engine work, there was just some residual oil being cooked-off the exhaust? maybe others can comment with better knowledge.
perhaps the perceived cost of new cars has decreased our tolerance for minor/moderate issues? Or, because we feel obligated to keep cars longer due to the increased investment, , we are more likely to experience multiple problems with it? Or the CAFE and other regulations has made DIY more difficult/expensive? anyway, these charts don't really support a decrease in quality; I couldn't find a chart for 'inflation adjusted historical cost of ownership of a new car' after a brief search, that might be interesting.
one possible explanation is CAFE - I read that the rules as of 2016 were particularly difficult for car makers. and it started a long time ago; plastic headlight lenses, 'donut' spare tire, smaller batteries, smaller rear brakes, air-cut valves, thinner glass, more aluminum, cvt, etc. Kinda surprised we don't have stop-start mandated here yet. (of course, each time some future change to the rules is announced, manufacturers begin making changes a few model years before the requirements)
