105
possible TPS problem? maybe use an analog ohmeter and check that it it smooth thru it;s range.
if you still have the old axles measure the compressed length and compare to compressed leght of new axle ? OBS is Impreza chassis - NOT the same as Legacy Outback - maybe some ordering or inventory stocking confusion. here's one thread I found with a few numbers, maybe not Impreza though? ;http://www.ultimatesubaru.org/forum/topic/84277-cv-axle-lengths/
- 15 replies
- OBS
- 5 speed transmission
(and 1 more)
Tagged with:
OK - wild idea here - is it even possible that the axles are too long? And if they were, can they stress those retainers maybe when the suspension compresses?
- 15 replies
- OBS
(and 1 more)
Tagged with:
weird did you install different axles?
- 15 replies
- OBS
(and 1 more)
Tagged with:
sounds like you have the green diagnostic connectors under the dash connected. They cycle the fans and all the solenoids. disconnect them. have you called the gas station again? You might try to find other 'victims' in your area - dunno how - maybe a 'consumer advocate' TV reporter? anyway - that fuel looks awful - maybe a truck still had diesel in it or ??? - do either of the fluids smell like alcohol? I have heard of ethanol being added and they rely on the driving to mix it in - but there;s speculation that it may not work if the a delivery is made quite near the terminal. interesting.
- 27 replies
- electrical
- relay
(and 3 more)
Tagged with:
uneven length headers feeding the turbo is mostly what makes that distinctive sound. a full swap of engine, trans and rear diff would be best. ' Impractical ' to just add a turbo to an NA engine. you CAN make you car more fun to throw around the corners - weight reduction, stickier tires, heavier springs/antisway bars, etc. "it's more fun to drive a slow car fast than a fast car slow"
call the gas station and ask if anyone else has complained about bad fuel. can you get the flash code out of the ecu? post the number(s) here.
- 27 replies
- electrical
- relay
(and 3 more)
Tagged with:
are you sure there wasn't a single click? as said, 17 year-old starter could easily need a solenoid rebuild - cheap and fairly easy. next time it happens, have a piece of 2x4 to whack it. that often gets things working. Also, try 'popping' the brake pedal, I think there's a switch there that can disable starting.
rotors may be OK - read about 'uneven pad deposits' - even if they need replacing, as said fairly easy and not crazy expensive parts. I'd get Centric rotors from RockAuto or maybe amazon. 2008 should have HBA bearing - Timken from RockAuto would be my choice I think. if the a/c system has not sat exposed to the atmosphere, get a junkyard compressor, 2 new o-rings and schrader valves inserts, 22 or w'ever ozs of refrigerant and fix it. blower motor? dunno how hard to swap out, might be fiddly but likely not difficult. new cabin air filter while you're there. you might find DIY threads and youtube videos for most of that work.
what's wrong with the a/c comp? many times, Subaru owners replace a coupla o-rings, maybe the schrader valves, recharge the system to the amount listed on the label under-hood and have no problems after that. quite common for the suction and discharge hose connections to need o-rings. occasionally, the clutch needs to be adjusted or a bearing goes bad.
My wife really wants a newer/new car. I might consider a 2-3-maybe 4 year-old Forester but know little about them. What years were the oil burners? where is the model year break? any glaring problems to look for? (I may try to keep my other cars even though it would be easier financially to trade one in. I love my WRX , and keeping her Outback makes it easier to have a spare car that non-manual drivers in the family can borrow) I'm sure she's in a hurry - but I'm not
should be one small bolt - up top at the front under the alternator. you can google search for pics probably - might even be a youtube video. there have been a coupla reports of folks wiping grime off of the sensor and it works - but they are not expensive sensors so, new one is a good value. can;t rule-out a connector/cable problem either until you examine it. also, be aware your car is due for a timing belt system service unless already done. Due at 105K miles OR 105 months, whichever is first. major valve damage if that system fails. $$$$
