105
warranty work? if so, try another dealership. if not, ask in a new thread for a shop near you - maybe someone can direct you to a good brake mechanic. it would be nice to know if air is actually found in the system when they bleed it.
- 1 reply
- brakes
- soft brakes
(and 1 more)
Tagged with:
any CEL codes? maybe scan after the no-start. kinda seems like a fuel issue - perhaps the Engine Temp Sensor. (might be 2 temps sensors on your car, the 2 pin/wire unit would be the ETS. if you have a single sensor, it will have 3 wires) It is supposed to signal the ECU when temps are cold so the injectors can be opened more - like a choke on old carb systems. But, you said it runs well - does that include when it does start at cool temps? ever smell fuel in the engine bay? some Imprezas have had fuels leaks at cold temps - just loose clamps usually. Never read of that causing a no-start though....
even if it is LSD - it's a sealed viscous unit and the gear oil never mixes inside the unit. something like the 80w-90, or a 75w-90 would be fine. And in the rear diff, it can be synthetic or conventional. If the car was purchased with the Weather Package, it may have rear VLSD - not sure. (maybe someone here will know, or dig around at cars101.com) if you put the entire rear up in the air on jacks - spin one wheel in forward travel direction. If the driveshaft is free to spin and the other wheel moves in forward travel direction - you have LSD. Open diff; the other wheel will move in the opposite direction.
looks like, under some rare situation, you could fold-up the liner. Might take just the right sized clump of ice or mud ? you could swing by a collision center or 2 and ask if they could at least make sure the liner is still secure - they might not charge you if it only takes 2 minutes to check it - I suppose it 'could' cost $50-$100 if they actually find a problem. Check google reviews and/or yelp if you actually want to use a collision center. I'd be tempted to just drive the car. Deal with any problem when it becomes more obvious/annoying.
rpm see saw
1 Lucky Texan replied to MrB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
scan the ecu for a pending code. yes, on a 10 year old car, it could be an O2 sensor. But a little more diagnosis might save you some money if it's a vacuum leak or poor ground connection, or ??? 07 I believe are also DBW and there could possibly be an issue with the accelerator pedal. -
that would be a rare failure but, as you say, you could just take it back for the trans repair. I do wonder though - is there a chance the previous owner or the dealer put an incorrect final drive part on the car? Tires must also all match size/brand/model. (seems unlikely a Subaru dealer would overlook the obvious though, but, you just said 'dealer'......) note also - u-joints and perhaps the carrier bearing can also exhibit problems similar to TB.
I may not be able to help much with the ID issue, but I'm jumping in to suggest you keep the rotors if possible. If they are in OK condition and above the minimum thickness stamped on them, keep them. Of course, if they are untrustworthy slabs of rust, that's a different issue. Subaru OEM rotors are fine quality.
did it smell like 'toasted marshmallows' ? that is definitely coolant. rattling noise may indeed mean the engine is not 'economically' reparable. Even if the rattling is from bent valves due to a slipped timing belt, the rod bearings could have overheated. many people opt for used engines from junkyards or imports from Japan. If you like and trust your mechanic, have a converstaion as to how he arrived at the price. maybe he is 'high-balling' it because he doesn't want to do the work? You can also ask for a shop recommendation in a new thread - maybe someone knows of a good Subaru shop near you.
- 5 replies
- overheated
- dead engine
(and 1 more)
Tagged with:
